car shakes when i put in gear
hi, i have a 2000 civic ex. when i sit at a red light in nuetral its fine. but when i put it in 1st gear my car begins to shake. is there something wrong with my tranny? it only shakes in first gear btw
I have this same problem with my saturn at low rpm in 5th... I want to guess that the gear is going out. At first i thought it might be the clutch going bad, but then I figured it'd do it in every gear. Could also be something with the axles... Like I said though, I'm just guessing here.
When exactly does it shake? When you're just sitting at idle, when you put it in gear but still have the clutch pressed, or when you go to take off?
it shakes when i am at idle, clutch pressed, in gear. it only shakes for about 5 secs max. then stops. and happens once in a while
Austin
Dec 1, 2003 12:04 PM
