wont start
so i bought a 93 civic coupe a couple days ago.....its stock d16 sohc vtec...i picked up the car from my buddys started no problem was drivin an i realized the tach dropped than came back up....so i turned the car off it started after that so went for anthoer spin...now car wont start any ideas? it starts but dies inlike no time..
thanks alot
thanks alot
Dont want to thread jack but im having a similar issue. when I was heading to work my guage would move up and down and when I went to a complete stop the car just died. no power what so ever. I tried turing the car and it would turn on but it would die right away. I waited about five minutes and started the car again. This time it stayed on. I drove back to my house and left it there. I called the previouse owner and he told me that he had problem with the igniton switch. Im wondering if I have to replace the whole thing with a brand new set of keys or just the wire. First I thought it was the alternator but im pretty sure its the ignition switch. Any thoghts?
I had the exact same problem and spent over $500 to have another distributor put in. That was a waste of money. It won't do it all of the time but sometimes the old girl just doesn't want to start. Sometimes after waiting ten minutes to 1/2 hour I'll try again and she'll start. I started using premium gas and it only happened to me once, briefly, since the switch to high test.
My guess is that one of the sensors is screwy, but only some of the time so it's near impossible to diagnose without a scanner at the house; which I don't have.
P.S. I don't think it's a ground wire because everything works except fire.
like when i start the car it sounds like its gunna fire up but it just dies =( i think something with the charge system cant be right...like an altenator or bad battery connection or maybe loose ground....it cant be fuel pump i hear it prime...car has full wire tuck if that matters with fuse box in glove box...
thanks alot
thanks alotIts not the main relay. A main relay wont kill the car once its running, it will only prevent it from starting. So if it starts and runs, then dies, look elsewhere for your problem.
This sounds like a classic bad main relay.
The main relay sits underneath the dash on the driver side.
It looks like this:
Here is how you can test it:
http://autorepair.about.com/cs/troub.../aa010301c.htm
It looks like this:
collkid
13
Sep 16, 2015 09:10 PM
fortymcpants
11
Jul 19, 2008 08:03 AM
westsideaznboi
27
Apr 24, 2008 04:45 PM
