wont start
so i bought a 93 civic coupe a couple days ago.....its stock d16 sohc vtec...i picked up the car from my buddys started no problem was drivin an i realized the tach dropped than came back up....so i turned the car off it started after that so went for anthoer spin...now car wont start any ideas? it starts but dies inlike no time..:thumbdown: thanks alot
Re: wont start
bumpppp! no one any ideas?
Re: wont start
main relay? thats what im thinking
Re: wont start
Explain more.
maybe bad battery connection or relay. |
Re: wont start
fuel pump?
Re: wont start
No start possible causes
1. Spark 2. Fuel 3. Inlet restrictions 4. Exhaust Restrictions 5. Voltage 6. Engine Mechanical |
Re: wont start
Originally Posted by Jonathannx2
(Post 41092107)
Explain more.
Re: wont start
coil? they're tricky lil bastards sometimes
Re: wont start
They don't have coil packs, they use a distributor.
Re: wont start
Originally Posted by itsnotfast
(Post 41093763)
I agree with the bad connections but I believe if a main relay goes bad the car wont start at all.
Re: wont start
Dont want to thread jack but im having a similar issue. when I was heading to work my guage would move up and down and when I went to a complete stop the car just died. no power what so ever. I tried turing the car and it would turn on but it would die right away. I waited about five minutes and started the car again. This time it stayed on. I drove back to my house and left it there. I called the previouse owner and he told me that he had problem with the igniton switch. Im wondering if I have to replace the whole thing with a brand new set of keys or just the wire. First I thought it was the alternator but im pretty sure its the ignition switch. Any thoghts?
Re: wont start
happened to me and all it was was the ground wasnt loose
Re: wont start
Check your transmission ground, thermostat ground, and motor ground.
Re: wont start
Exact thing happened to me, was just a loose ground.
Re: wont start
(Post 41094237)
Re: wont start
I had the exact same problem and spent over $500 to have another distributor put in. That was a waste of money. It won't do it all of the time but sometimes the old girl just doesn't want to start. Sometimes after waiting ten minutes to 1/2 hour I'll try again and she'll start. I started using premium gas and it only happened to me once, briefly, since the switch to high test.
My guess is that one of the sensors is screwy, but only some of the time so it's near impossible to diagnose without a scanner at the house; which I don't have. P.S. I don't think it's a ground wire because everything works except fire. |
Re: wont start
like when i start the car it sounds like its gunna fire up but it just dies =( i think something with the charge system cant be right...like an altenator or bad battery connection or maybe loose ground....it cant be fuel pump i hear it prime...car has full wire tuck if that matters with fuse box in glove box...
Re: wont start
Originally Posted by slow joe
(Post 41099977)
Re: wont start
update???
Re: wont start
check your alternator connections it will do that if your alternator is not connected well or is going out.
Re: wont start
(Post 41085214)
Originally Posted by skaternak
(Post 41092062)
Originally Posted by cajuncharger
(Post 41098792)
My guess is that one of the sensors is screwy, but only some of the time so it's near impossible to diagnose without a scanner at the house; which I don't have. P.S. I don't think it's a ground wire because everything works except fire. This sounds like a classic bad main relay. |
Re: wont start
Where is the main relay located and is there a way to test it?
Thanks, Bob |
Re: wont start
The main relay sits underneath the dash on the driver side.
It looks like this: https://img359.imageshack.us/img359/2499/30e97po.jpg Here is how you can test it: http://autorepair.about.com/cs/troub.../aa010301c.htm |
Re: wont start
Great info, thanks a bunch.
