Axle Nut 2 Tight?
Old Sep 3, 2002 | 04:19 PM
SikofFalln's Avatar
Default Axle Nut 2 Tight?
On my 89 civic w/ LS swap, when I tighten down the passenger side axle nut the hub will not spin freely. Loosen it up and tap out the axle abit and it spins again. I think I may be compactiing my wheel bearings, but if that is true how do I tighten down the axle nut. I didn't have this problem the last time I changed my axles, could my wheel bearing be shot? There is no side 2 side or up and down motion with the wheel on.
Old Sep 3, 2002 | 04:43 PM
SikofFalln's Avatar
Default Re: Axle Nut 2 Tight? (BseriesPWR)
ttt
Old Sep 4, 2002 | 11:38 AM
SikofFalln's Avatar
Just incase any one else has this problem I will answer my own question. On the reman axle I have the dust sheild was tightening down against the hub causing it not to spin. Removed the dust sheild, problem solved.
black0hatch
Honda CR-V & Element
Sep 16, 2016 02:53 PM
wubanga
17
Jul 8, 2009 09:09 PM
captain_crunch
Suspension & Brakes
Jul 26, 2008 06:40 PM
wraetthu
Nov 17, 2006 03:56 PM
servion
Sep 5, 2003 11:33 AM
