need help with stripped block!!!
Old Dec 28, 2009 | 07:30 PM
jyracer's Avatar
Default need help with stripped block!!!
im doin a b20vtec swap into my dc2, i got it all the way in and was bout to put the head on and one of the holes where the head bolts screw into the block is stripped out (ofcourse its the center one on the intake side....) but i tried putting a helicoil in it but it just sits there and spins down in it, is there nething to do bout this? has ne1had this problem? i need to kno how to fix it!!!
Old Dec 28, 2009 | 07:34 PM
92civiceg9gsr's Avatar
Default Re: need help with stripped block!!!
use a Timesert.
Old Dec 29, 2009 | 06:12 AM
jyracer's Avatar
tht will def. wrk but they dnt reopen till january 4th,.... i need this on the road asap its my dd, is there nething else?
Old Dec 29, 2009 | 07:08 AM
Alex M.'s Avatar
Can't you just drill and tap the head and block to the next size up?
Old Dec 29, 2009 | 07:11 AM
josh-roy's Avatar
^lol
Old Dec 29, 2009 | 07:13 AM
Alex M.'s Avatar
Originally Posted by josh-roy
^lol
Ok I guess not....
Old Dec 29, 2009 | 07:24 AM
jyracer's Avatar
if i were to do tht wat head bolt would i use?
Old Dec 29, 2009 | 10:02 AM
Zappythebum's Avatar
well there is nothing saying you cannot drill and re-tap the hole to the next size, but you should have a machinist do that.. trust me you wouldn't want to mess up.
if you are wanting to do this yourself here is a seemingly informative link: http://www.yourepair.com/2009/03/06/...d-threads.html
Helicoils are a good way to go too if you just want to replace the old thread with new thread of the same size, check them out:
http://www.emhart.com/products/helic...iex/design.asp
edit: to answer your question
the stock head bolts are 11mm i believe so you would be using somewhere in the 12mm range if you were to up the bolt to the next size
willard steen
Apr 5, 2016 12:22 AM
gooblinn258
Apr 22, 2014 08:50 AM
5thgencivic
Mar 14, 2011 11:56 AM
The93egg
Feb 22, 2009 09:32 AM
steven_highet
Jan 25, 2009 11:47 AM
