HTH do you get the crank shaft pulley off????????
Old Sep 3, 2002 | 12:18 PM
89 CRX SI's Avatar
Default HTH do you get the crank shaft pulley off????????
is it posible without a impact gun??? breaker bar and brakes on. will that work??????
Old Sep 3, 2002 | 12:37 PM
keithv's Avatar
Default Re: HTH do you get the crank shaft pulley off???????? (89 CRX SI)
there was a post on this just last week!
https://honda-tech.com/zerothread?id=266520
Old Sep 3, 2002 | 12:55 PM
89 CRX SI's Avatar
Default Re: HTH do you get the crank shaft pulley off???????? (breaka_1_9)
well i tried all that **** ieven put my car in fierst and pushed backwards and droped clutch the tires just lock and it wont come off. Nothing works any other ideas.
Old Sep 3, 2002 | 01:02 PM
89 CRX SI's Avatar
what about going forwards and dropping it in reverse. i just dont wanna tightne it more
we tried breaker bar for like 2 hours so piece.
Old Sep 3, 2002 | 03:52 PM
Malgerus's Avatar
Hey 89_CRX_SI, how's that head swap working out for you?? Good luck with the crank pulley bolt. Never did manage to get it off my D16A6. For you, get like a 4 foot bar, spray the bolt with a penetrating oil, and LIGHTLY tap on the bolt to let the stuff work in.
Old Sep 3, 2002 | 04:37 PM
MNCRXSi's Avatar
Default Re: HTH do you get the crank shaft pulley off???????? (89B16HB)
Heh, when my friend owned my CRX before I did, the nut fell off as we were driving it! Herd a loud clunk (thought we ran something ovre) but 1/2 hour later, his radar dectior started going nuts because it was "low voltage" than the ALT like came on. Hehe, but it was almost 20 bucks to replace it!!
Old Sep 3, 2002 | 05:57 PM
89 CRX SI's Avatar
Default Re: HTH do you get the crank shaft pulley off???????? (MNCRXSi)
my problem is different ive tried all it said in the old post. It still wont come off.
If i left the oil jet in the old block VTEC wont work on my engine? The car will run fine tho?
THX guys
Old Sep 3, 2002 | 06:07 PM
therealciviczc's Avatar
For the 10 billionth time... If ALL else fails.... LOCK THE FLYWHEEL IN PLACE with a bolt through the bell housing, another bolt through the flywheel, and something in between.... Spend hours if you have to, making something that will hold the flywheel and won't budge no matter what you do to it. Now get your breaker bar, and put a HUGE pipe over it.... I say go for something at least 6 ft long, maybe longer. If the pulley doesn't come off, the crank will break and you won't have to worry about it. I only recommed the above method if EVERYTHING else fails.
Old Sep 3, 2002 | 06:22 PM
89 CRX SI's Avatar
Default Re: HTH do you get the crank shaft pulley off???????? (therealciviczc)
treid it with a 4ft bar. im gonna get a 500 ft lb professinal imapct gun and air tank from a friend. he said it will do the job hes done it on his car.
Old Sep 3, 2002 | 06:58 PM
CimorelliCRX's Avatar
This is how you do it. Get a huge breaker bar, with a huge cheater. Get a screwdriver and go from down where the oil pan is, and lock the flywheel up, take the dustcover off. ONce you start turning it, it will lock the flywheel and break the bolt right loose. Thats the easiest way.
Old Sep 3, 2002 | 07:04 PM
Lt. Dan's Avatar
Default Re: HTH do you get the crank shaft pulley off???????? (CimorelliCRX)
take it to a shop, and pay some guy 5 bucks to throw his impact on it.....
Dan
Old Sep 3, 2002 | 07:46 PM
89 CRX SI's Avatar
Default Re: HTH do you get the crank shaft pulley off???????? (Lt. Dan)
ok we tried all that brok 2 screw drivers 1 breaker bar and a ratchet. .... im talking were using a 6 foot breaker bar.
im gonna tow it gor 15 bucks to a shop get them to do it for free and tow back. worth the 15 bucks i guess.
Old Sep 3, 2002 | 08:05 PM
ZCivicTurbo's Avatar
just get a portable camping propane torch from Home Depot or Sears and heat that SOB up for about 30-45secs good maybe more and then use the impact gun ot breaker bar on it.
tinyscivic
Feb 27, 2010 10:25 PM
Draggin99Si
59
Feb 20, 2005 11:59 AM
luti
28
Jan 9, 2005 01:05 PM
justinau
Sep 4, 2004 01:31 AM
mike1114
Jan 31, 2004 03:19 AM
