Headlight - one doesn't work
Old Dec 23, 2009 | 09:32 AM
xyk's Avatar
xyk
Default Headlight - one doesn't work
Problem is with passenger headlight. The bulb in question is the one in the smaller housing on stock eg lights. It used to work. Car sat in my backyard for 1.5 years. Doesn't work now.
Already swapped bulbs with the respective driver side one. Bulb not the problem. Engine bay and underdash fuses all good. I think it's a wiring issue but not really sure where to start with the multimeter. I also just learned how to use a multimeter in preparation to diagnose this issue.
Just looking for some direction I guess...
Old Dec 23, 2009 | 01:46 PM
xyk's Avatar
xyk
Default Re: Headlight - one doesn't work
Old Dec 24, 2009 | 02:39 PM
xyk's Avatar
xyk
merry christmass upp
Old Dec 24, 2009 | 05:04 PM
Boosted_01 R's Avatar
most likely its gonna be wiring. sometimes when a car sits that long, moisture gets in the wiring, and in the winter the moisture freezes damaging the wire.
Old Dec 24, 2009 | 05:17 PM
Anon51's Avatar
why don't you check if you're getting power at the bulb socket? using a power probe look for 12v and Ground.
Old Dec 24, 2009 | 10:27 PM
jordaninu's Avatar
TRY A TEST LIGHT ON ALL THE HEADLIGHT CONECTORS AND FUSSES....HAS TO BE A WIRING ISSUE
Old Dec 25, 2009 | 12:40 AM
hondadcba's Avatar
check the headlight bulb socket
Old Dec 25, 2009 | 01:18 PM
ImportHatch's Avatar
Check and see if the bulb plug is corroded. Seems odd the wiring would be changed unless a rodent got in there and nawed something up.
russ donnan
13
Jan 12, 2019 05:49 AM
dlewis2583
Oct 7, 2010 09:34 AM
sprayedcrx
13
Sep 22, 2004 09:46 PM
accord ex
Mar 13, 2003 05:55 PM
