Headlight wiring
Re: Headlight wiring
Car?
Three wire is usually for double filament bulbs
Look at bulb
The two filaments have a common lead
That lead is for ground
The two others are for power to each filament
Before replacing, look at old wiring and how bulb goes in
This should help clear things up
Note: Should make sure wring has good contacts
Having a gap or bad solder or butt connector will cause resistance and burn out of wiring
Look at bulb
With car information, one can tell OP how to connect the stock wires to provide headlight functions as intended by Honda.
How to connect wires to a headlight socket only takes a little understanding of how electricity works and how a circuit functions
It isn't rocket science and doesn't require a degree from the college of Honda cars ... hahaha
O.G. triple O.G.
sageuvagony
10-04-2008 09:07 PM
