200 WHP from B16A2 Possible?
Old Sep 3, 2002 | 11:34 AM
miyo's Avatar
Default 200 WHP from B16A2 Possible?
I know that it isn't worth the money to many people but can you extract 200 WHP from a B16A with the following:
Ported Head and Intake Manifold
Bored TB
Skunk 2 Stage 2 or Toda B Head Package
Golden Eagle Sleeved Block at 84.5
Eagle Rods
IB Pistons
GSR(87.2) or LS Crank(95)
12:1 Compression...
Any thoughts as to if 200 WHP is possible?
What crank would produce more power?
Thanks....
Old Sep 3, 2002 | 11:36 AM
poison's Avatar
Default Re: 200 WHP from B16A2 Possible? (miyo)
very possible with what set up you described.
i believe with the LS crank you'd make more torque, but having the GSR would probably make just a little more top end and just a slight less torque as the LS.
correct me if i am wrong
Old Sep 3, 2002 | 12:25 PM
W.Zero's Avatar
with all that you better make 200 but you really dont need the crank. you might wanna spend the extra cash on other parts like fuel, ignition, and other bolt on performance parts
[Modified by W.ZeroB18C1T, 9:28 PM 9/3/2002]
Old Sep 3, 2002 | 01:43 PM
Jimmy L's Avatar
Default Re: 200 WHP from B16A2 Possible? (W.ZeroB18C1T)
I didn't think you could use a GSR or LS crank in a b16 block.
Old Sep 3, 2002 | 01:53 PM
HXMan's Avatar
Default Re: 200 WHP from B16A2 Possible? (Jimmy L)
You could, but he would need custom short rods, and there goes his R/S ratio to HORRIBLE. Stock b16 rod ratio is nice, with a relativly short stroke keeping piston speeds down. With the 84.5mm bore the engine should be near to 1.8L, with good R/S ratio, and a great powerband. The larger bore will open up the valves alot too!
Old Sep 3, 2002 | 02:17 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: 200 WHP from B16A2 Possible? (HXMan)
I'm at 201.3whp with my setup
Old Sep 3, 2002 | 02:18 PM
2point6's Avatar
Default Re: 200 WHP from B16A2 Possible? (FrostyDC4)
What kind of TQ do you have?
Old Sep 3, 2002 | 02:20 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: 200 WHP from B16A2 Possible? (2point6)
139.8
Old Sep 3, 2002 | 02:26 PM
HXMan's Avatar
What is your setup?
Old Sep 3, 2002 | 02:29 PM
Spade's Avatar
Bored TB
Eagle Rods
IB Pistons
12:1 Compression...
Thanks....
That would be pretty damn close.
Old Sep 3, 2002 | 02:30 PM
miyo's Avatar
What is your setup?
Old Sep 3, 2002 | 02:37 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
93 GSR:
B16a
Ported and polished head
Extrudehoned type r im
RC 65mm TB
Head milled .002''
Jun3 cams (not much clearence)
Jun valvetrain and Jun ECU
STOCK 81mm bore
JE 12.5cr pistons (unsure about cr though b/c of milled head)
Eagle Rods
ARP Head bolts
Fully balanced, polished, counterweighted, and knifedged crank
ACT clutch and flywheel
Apexi VAFC
I think thats it
This car owns my wallet
[Modified by FrostyDC4, 3:42 PM 9/3/2002]
Old Sep 3, 2002 | 02:39 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
200WHP from a B16 is possible it just takes money
Old Sep 3, 2002 | 02:46 PM
ALLMOTOR18's Avatar
wow... too much $$$ to make 200whp in a b16a...
<~~ for doing it..
[Modified by GSRTypeR, 11:46 PM 9/3/2002]
Old Sep 3, 2002 | 07:57 PM
carcala's Avatar
what are ur times for that setup??
Old Sep 3, 2002 | 09:22 PM
976's Avatar
976
New User
Default Re: 200 WHP from B16A2 Possible? (carcala)
B16a > ECU > Turbo
Excuse me if your going only NA.
If you can fit a B18C5, less mods to produce 200 whp. Maybe lower price. IF luckey.
Old Sep 3, 2002 | 11:21 PM
MikeSarr_GSR's Avatar
Default Re: 200 WHP from B16A2 Possible? (w00t!)
with that 93GSR tranny, he should be in the high 13s fast as crap... Xsi'd 93 GSR... nice choice
Old Sep 4, 2002 | 06:14 AM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
I havent had the chance to get any times this summer b/c I had to work 2 jobs to pay for this s... . I'm hoping for high 13's with this setup. Just a week ago I put a couple of buslengths on a GS430 on the highway going from 70-120
Old Sep 4, 2002 | 06:39 AM
Jeff C's Avatar
93 GSR:
B16a
What happened to the B17?
Old Sep 4, 2002 | 06:41 AM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: 200 WHP from B16A2 Possible? (Jeff C)
I bought it w/o a motor
Old Sep 4, 2002 | 12:57 PM
carcala's Avatar
u should do atleast low 13's. I do low 14's with street tires but with slicks i know it could do high to mid 13's.
jebusdc2
Nov 19, 2011 09:50 AM
Natural Aspirations
66
May 11, 2006 01:03 PM
94si94cx
Jun 21, 2004 10:49 AM
B18PoweredCivic
28
Jun 10, 2004 04:08 PM
ChiBoy
Nov 25, 2002 05:15 PM
