Is this Turbo Right for my goal (425-450whp)??
Old Dec 22, 2009 | 06:57 PM
MTVtec's Avatar
Default Is this Turbo Right for my goal (425-450whp)??
So i got a Turbonetics turbo that i cant find much info about. I tore it down and measured wheels and googled for an hour or so...Ill list what ive got:
To4e compressor housing(looks to be a .60 A/R but i cant find a # on it)
57mm Inducer
76mm Exducer
56 trim
Compressor wheel appears to be very close to gt3076 wheel...44lbs/min
.50 A/R T4 Turbine housing 3" v-band outlet(not sure how .50 A/R would convert for T3)
63mm Inducer
74mm Exducer
74 trim
Turbine wheel appears to be the same as a gt32.
Also it is journal bearing(i think...look like brass bearings to me but why does it run water & oil?)
My setup is below:
GSR block stock sleeves
81.5mm CP 9:1 pistons
new bearings
new seals
Eagle rods
arp studs
oem HG
GSR head
Supertech valvetrain
Supertech guides and valves
mild port job
Victor X intake mani
65mm TB
Spoolin mini ram
Spoolin 3" dp
38mm turbosmart ultragate
full 3" exhaust
So i know im not going to spool this thing for **** but i didnt know about the .50 A/R hot side...it seems small and with the mini ram im hoping gas velocity will be decent. Im shooting for anything over 400whp but would like to b closer to 450 and have full boost by 5k. Possible???
Is this turbo going to be way out of its efficent range? I could still go a different route with the turbo but would like to use this unit if i can. Any advice/theories would be appreciated!
Old Dec 22, 2009 | 07:00 PM
DA TeG 90's Avatar
Default Re: Is this Turbo to big for my goal (425-450whp)??
For the power your looking to make the gt3076r is the best choice IMO. One of the best "street" turbos and the powerband / spool is the best!
Old Dec 22, 2009 | 08:02 PM
MTVtec's Avatar
yeh thats the impression im getting...how about the stock sleeves? Is there a pressure limit or more of a power limit on them? I plan on venting the block and valve cover just to be safe.
Anybody running similar setups, what can i expect?
Old Dec 22, 2009 | 08:12 PM
TheShodan's Avatar
Moderator
There are SOOO many others in the category, we'll have to show you the other options from the Garrett / Borg-Warner and Holeset camps. That's one turbo out of 10 that can do the job. Let's look to his requirements more before coming to such a quick conclusion (though I understand this was simply your OPINION.)
Old Dec 22, 2009 | 09:20 PM
ghostofnyc's Avatar
mac sounds like a silver surfer candidate
Old Dec 22, 2009 | 09:44 PM
Trust-Me's Avatar
i still deciding on my turbo set up too, will be interesting to see what others have on this setup.
Old Dec 23, 2009 | 06:02 AM
MTVtec's Avatar
Anyone running gt32 or comparable turbine wheel with stock bore or close to it chime in and post spool times...although im not sure how the .50 A/R T4 housing will respond?
Old Dec 23, 2009 | 05:54 PM
MTVtec's Avatar
ttt
Old Dec 23, 2009 | 06:40 PM
TheShodan's Avatar
Moderator
Tell MTVtec all about it ;-) I'm sure he's curious and would love to know from one who has that experience.
Old Dec 24, 2009 | 08:07 PM
ghostofnyc's Avatar
Default Re: Is this Turbo Right for my goal (425-450whp)??
Ultimate street turbo not a lot of lag depending on load of the motor by 3800-4200 rpms I would see full boost 15psi car was only street tuned conservatively been in my fair share of high hp turbo fwd cars and very big difference delivery of boost. A 4000-5000 rpm power band is easily attainable and very predictable reminds me a lot of a gt30r with more top end and best part of all its rebuild able
Old Dec 24, 2009 | 10:06 PM
VtecHusker's Avatar
run a holset
boosteddohczc
Apr 19, 2012 06:30 PM
precisionsc54
Apr 21, 2009 01:19 PM
AJxr
Nov 15, 2008 12:12 PM
vtiperu
Nov 21, 2007 10:09 AM
frogscivic
Apr 21, 2003 06:58 AM
