how necessary is an oil catch can?
Old Dec 22, 2009 | 09:58 AM
Clash0901's Avatar
Default how necessary is an oil catch can?
im turbo'ing my b20 rex and i was told i dont need an oil catch can.
what are the benefits of having one and can i go without it?
Old Dec 22, 2009 | 10:00 AM
welfarepc's Avatar
Default Re: how necessary is an oil catch can?
catch cans do what you think, catch oil.
you can easily vent your block to atmosphere and just run a hose off and to the ground. so no, you dont need one.
but if i see you doing that at the track, prepare to get punched in the face. i dont want to hit an oil slick at 200km/hr
Old Dec 22, 2009 | 10:27 AM
miguel329's Avatar
^ LOL!!
Old Dec 22, 2009 | 10:55 AM
SPOOLINmatt's Avatar
round house kick to the face if i see someone venting to the ground.
Old Dec 22, 2009 | 03:28 PM
tegman23's Avatar
lol...he is right... though i used a beer can before i got my real setup lol
Old Dec 22, 2009 | 03:36 PM
LightningTeg's Avatar
Community Builder
I think they're neccesary. Since I've melted the plastic that holds the dipstick in place, oil vapor shoots out of it when I boost if the catch can isnt hooked up.
The pressure will find a way out one way or another; whether its the dipstick hole in my case, or your oil pan or valve cover gaskets.
Old Dec 22, 2009 | 05:04 PM
accord_raffi's Avatar
I would say any turbo application should have a properly set up crankcase venting system. But depending on your boost level, your stock pcv system might be able to vent it enough. Basically when you're running a FI setup, you can create positive pressure in your crankcase. This pressure needs to be relieved otherwise it will find other ways to escape like out your dipstick, piston rings (causing you to burn oil), and through any other gap it can find.
Old Dec 22, 2009 | 05:41 PM
boostedcivicsir's Avatar
Mr. Badwrench
its no myth that even stock honda engines dont breathe well.
yes you will benefit from a catch can. and yes you will probably get punched/roundhouse kicked if you vent to the ground.
look in the faq's at the top there are a few threads pertaining to catch cans.
Old Dec 22, 2009 | 08:27 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
tony1 did a test, its in his profile and it shows a test that he did. no positive pressure to very little in the motor
Old Dec 22, 2009 | 11:15 PM
link me because i'm lazy lol
Old Dec 23, 2009 | 05:11 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
no. the time it took for you to type that in was the time i took to see it. Stop being lazy. look up tony1 and you can see it in his profile
4tika4
Feb 3, 2012 02:27 PM
auspilot
Feb 13, 2011 09:31 PM
shivic
12
Jul 3, 2007 11:21 AM
Serenity Now!
Jan 29, 2007 06:31 AM
