License plate with intercooler
Searched, but couldnt really find a definite answer..Will mounting my front license plate in front of my FMIC hinder anything performance (i.e. block significant airflow to the intercooler) wise? I just don't feel like getting harassed for no front plate
its a small intercooler and if its not a quality piece then it might be an issue but it also depens on how much boost your going to run and what size turbo. if your running a small turbo and trying to crank the boost then intake temps are going to get high if the intercooler isnt working 100%
It is rather small you should be ok and should not have any cooling issues either. I didnt have any when I ran the smaller IC but when I started upgrading to bigger ones damn did that block flow to my RAD
my turbo is small and i'm bosstin about 7psi daily driven. i just put on the license plate back on. imma see how the car runs for a couple of days and if i notice any significant change. Thanks for all the replies
This may be silly but did you touch your cold side charge pipes to see if they were any warmer after a pull now that you have a license plate in the way?
melovesboost
Apr 8, 2007 05:59 PM
ladysman
Sep 17, 2005 11:00 AM
