turbo wont kick in
Old Dec 21, 2009 | 11:15 AM
cslegacy's Avatar
Default turbo wont kick in
i just got my car going a few days ago and its been running good, but on the way home last night when i reved it up to 4000rpm in 3rd gear it wouldnt go past that and felt like it was redlineing ,oil feed is installed correcty
this was working fine prior
b16a stock
crome tuned
r33 turbo top mount
spoon leads
Old Dec 21, 2009 | 11:33 AM
91gst's Avatar
Default Re: turbo wont kick in
I think a bit more information could help(engine management, turbo, electronics setup). I had a similar problem with my hondata s300 and my speed sensor(mechanical type) wasn't completely clipped in so it would trigger the 2-step. Couldn't rev above 4k rpm. Check for boost leaks, vacuum leaks and possibly fouled out plugs. Also, is your check engine light on? Hope this helps.
Old Dec 21, 2009 | 01:12 PM
cslegacy's Avatar
ok thanks i edited post
Old Dec 21, 2009 | 01:35 PM
welfarepc's Avatar
check engine lights??? sounds like limp mode.
Old Dec 21, 2009 | 01:46 PM
cslegacy's Avatar
im not getting any engine lights, also i took the car for a drive just then, runs fine no smoke it just does not boost at all 0 psi
Old Dec 21, 2009 | 01:49 PM
cslegacy's Avatar
its also running internal wastegate
Old Dec 21, 2009 | 01:52 PM
coryfenton's Avatar
Wastegate could be stuck open man! BOOST LEAK
Old Dec 21, 2009 | 01:53 PM
cslegacy's Avatar
i was thinking about that! ill have a look thanks man
Old Dec 21, 2009 | 01:59 PM
cslegacy's Avatar
hey thanks man, thats what it was, the cerclip fell of the wastegate and its stuck open
Old Dec 21, 2009 | 02:03 PM
GinsterVRT's Avatar
Will it make any boost? Could be blowing the spark out. Whats your plug gap set too? Also check your wires and make sure they are seated correctly and are not arcing to the head.
Old Dec 21, 2009 | 08:44 PM
coryfenton's Avatar
Hahaha... I knew it, as soon as you said internal wastegate.. dead give away. Good that you got it figured out man, have fun..
Old Dec 21, 2009 | 09:11 PM
welfarepc's Avatar
how an open waste gate stopped you from going over 4000rpm is beyond me.
lol, i laughed.
Old Dec 23, 2009 | 06:51 PM
PheonixYellowEG's Avatar
Check the timing my single cam did that too
Old Dec 23, 2009 | 07:12 PM
Vagitarian's Avatar
My guess is a popped off charge pipe
Old Dec 23, 2009 | 08:14 PM
boostedcivicsir's Avatar
Mr. Badwrench
lol, i laughed.
just to play devils advocate, when i had popped a charge pipe on the street, at 4k the car wasnt making any power anyway so no need to even try to rev it any higher.
maybe it just quit making power? and didnt have the need to try to keep accelerating.
Old Dec 24, 2009 | 12:58 PM
welfarepc's Avatar
i would hope that the tune would be resonable enough in the 0 vac column, but, you have a good point.
romoracing
Dec 3, 2008 06:10 PM
ProjectEG8
Jun 19, 2007 09:59 AM
hoskos
Apr 23, 2007 06:12 AM
racinskittle
Feb 16, 2004 10:50 PM
Ntrpriz
Jun 29, 2003 08:10 PM
