98 ex, abs problems
official honda whore
98 crv ex has the abs system, but at start up the light doesnt turn on for the cluster and it doesnt seem to work
i checked the fuse under the hood and there wasnt a 20a one in the spot, threw that in and still no abs light on cluster
is there any way to tell whats up
also the low fuel light doesnt work, is that supposed to?
i have a similar problem...
but my abs light stay on, from what ive researched,
the abs module by the ecu has it own power supply
or fuse, only the dealership knows how to "reset" it..
i never had a chance to tackle it as long as its not bothering
me and i dont do crazy driving anyway... but itll help a lot
this winter season..
you mighty wanna check the abs module above the ecu,
try to plug/unplug it,, then go from there...
good luck!
good luck!
When the bulbs go through the self check they are normally on and the unit connected to the bulbs turn them off, so if the ABS light isn't coming on I would wonder about the cluster 1st.
i was thinking of my problem..sorry!
cheack cluster lights first, switch/borrow bulbs
to other socket to test it, good luck!
Alcatrax30
Honda Civic (2006 - 2015)
Mar 10, 2016 02:57 PM
