abs problem
Old Dec 1, 2004 | 09:50 PM
shutupitsANDREW's Avatar
Default abs problem
i searched but couldnt find out what to do (not enough sleep). i recently had a problem with the abs cycling while braking under 10mph, so i bled the brakes and that fixed it but now my abs light is on. how would i go about so the light would go away? i heard about removing a fuse for 5 seconds and putting it back in what not sure, anyone have any detailed information? need some advice, thanks.
Old Dec 1, 2004 | 09:53 PM
jay_96teg's Avatar
Default Re: abs problem (djfuzziebear)
Don't cheat yourself on your abs, you may need it.
try to fix it not cut it out!!!
Old Dec 1, 2004 | 09:58 PM
Default Re: abs problem (jay_96teg)
opps sorry, dont think i gave enough information. the abs is working when its suppose to after i have bled the brakes. its just the abs light that wont turn off. how do i go about resetting the light?
Old Dec 1, 2004 | 10:03 PM
Jdm_black's Avatar
I believe its on the cluster fuse check it make sure all the bulbs is hook up right aight oyah and can u please help me sell my rims and my crx im a newbie here i need to sell the ride before i go back to my country thanks...
Old Dec 1, 2004 | 10:17 PM
marsbike's Avatar
From: Salt Lake City, Chicago at heart, UT or IL, USA
Default Re: abs problem (Jdm_black)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdm_black &raquo;</TD></TR><TR><TD CLASS="quote">I believe its on the cluster fuse check it make sure all the bulbs is hook up right aight oyah and can u please help me sell my rims and my crx im a newbie here i need to sell the ride before i go back to my country thanks... </TD></TR></TABLE>
It's not there on the integras. If you sit in the driver seat, just in front of your right knee is the underside of the dash. Reach under there, and you'll feel a square button. Put your car into Accessory mode, or where you'd put the car to pull the CEL code, and just hold the button. It should reset everything just fine.
Old Dec 1, 2004 | 10:36 PM
Default Re: abs problem (marsbike)
ah, i guess there is still something wrong with my abs. after holding the button it didnt reset the abs lights.
Old Dec 2, 2004 | 04:28 AM
JimBlake's Avatar
You could read the ABS error code, then you'll know. It's pretty much like reading ECU error codes, check out the sticky thread at the top of this integra board.
Old Dec 2, 2004 | 09:24 AM
Default Re: abs problem (JimBlake)
thanks, im gonna try doing that tonight.
Huntersdc4
Nov 21, 2014 05:43 AM
komat
Oct 8, 2010 05:37 AM
jkmacken
Oct 21, 2005 06:02 AM
steffexchik
Oct 16, 2003 04:41 PM
Lost Type R
Mar 22, 2003 07:32 PM
