d series shift forks
are dx and si cable trannys shift forks interchangable? i have a couple si trannys with broken shift forks and a spare dx tranny wondering if i can just swap the forks?
They should be, they hydro trannys you can as long as you stay within the same years ('92 - '95 and '96 - '00) I don't see why the older cable trannys would be any different.
I am a licenced tech and Ive had 26 Hondas. Ive worked on nothing but Hondas for approx 6 years. Ive built b-series trannies, and everything from high comp b-series engines to mini-me's. I currently have a Genuine EF9 Civic which I assisted in importing last year. I have never been able to get a d-series case to bolt back together without jamming the input shaft solid. Ive tried on multiple d-series transmissions using different techniques and parts and have even had the assistance of two Certified Honda Technicians at one point. These are throw away transmissions-dont waste your time, I spent over 10 hours on one d-series transmission in a professional shop, fully equipped with all required tools trying to put the case back together without jamming the input shaft, unsuccessfully.
X2
That goes to show you just because you have a patch (ASE) on your shoulder, you do not know everything
maritime_ef
Mar 29, 2011 07:10 AM
tony7626
Jan 22, 2010 03:56 PM
fastludeh22
Apr 8, 2004 07:01 AM
