Running temp/heat issues
Old Dec 16, 2009 | 06:00 AM
stdefhatch's Avatar
Default Running temp/heat issues
I did a few searches and didnt find much so ill try this out. Since winter started my car would always seem to run on the cold side, the temp gauge would only get to the mid way point if the car was at idle or i was in traffic. Other wise it would sit at around 1/4 past the C line. I recently swapped my motor last weekend and now it will only get to 1/4 past the "c" mark if im idling or in traffic. When driving on the hwy or in town it will be bellow the "c"line/mark like it is when you first start your car. When it actually gets up to 1/4 on the gauge it will blow out hot air, but of course when it drops it blows out cold air. My 1st guess was the thermostat but i wanted to see if anyone else has ever had this similar issue. Ive got my old/spare motor so i do have all of the sensors still on the block that i can use if i need to. Thanks in advance.
Old Dec 16, 2009 | 10:59 AM
mouab18c1's Avatar
Default Re: Running temp/heat issues
did you bleed your coolant system? if your temp gauge is surging back and forth then you have air bubbles in your system
Old Dec 16, 2009 | 12:01 PM
stdefhatch's Avatar
yes i did, and no its not surging back and forth.
Old Dec 16, 2009 | 04:01 PM
stdefhatch's Avatar
tried the ghetto cardboard trick in front of the radiator and that worked. might try swapping a few things out tomorrow since i havent gotten much of a response.
Old Dec 16, 2009 | 04:08 PM
HamiltonRex's Avatar
theres only a few things it could be. you don't need cardboard.
1. air in coolant or low coolant level
2. plugged heatercore
3. thermostat stuck open/opens too soon
sounds like a thermostat to me.
Old Dec 17, 2009 | 06:36 AM
stdefhatch's Avatar
yeah i know i dont need cardboard, i was using that as a temperary fix until i could get the time to really look at it. im gona flush the coolant and do a new thermostat asap.
Old Dec 17, 2009 | 07:57 AM
DVDr's Avatar
had the same problem on my old winter beater, drove half the winter with cardboard, then changed the thermostat and boom , it was nice and warm again.
The thermostat failed open ( as it should ), so the car really never had a change to warm up the coolant.
Old Dec 17, 2009 | 09:28 AM
stdefhatch's Avatar
hopefully thats all it is. ill see tomorrow afternoon.
Old Dec 19, 2009 | 08:44 AM
stdefhatch's Avatar
it was the thermostat, or actually the lack of thermostat. there wasnt one in there at all so that explains it.
Rotting Prelude
Jun 17, 2016 04:50 PM
the soL that could
Mar 14, 2009 06:20 PM
boarding2008
Feb 1, 2009 04:00 PM
Ti3d in
Aug 4, 2004 06:38 PM
Calavera
Jan 23, 2004 06:53 AM
