cranksahft dosen't spin
Old Dec 15, 2009 | 09:38 AM
qpe's Avatar
qpe
Default cranksahft dosen't spin
hi , just quicky
I've just assembled bottom of my h22 engine , all clearances were checked and seemed to be ok according to user manual
the thing is I can't spin the crankshaft , I should add there is no head yet .
Is it normal ...????
Old Dec 15, 2009 | 09:54 AM
Scott_Tucker's Avatar
Default Re: cranksahft dosen't spin
Did you check to see if the crankshaft is bent?
Old Dec 15, 2009 | 10:01 AM
qpe's Avatar
qpe
actually I didn't , but it was taken out of a car in working order never causing any problems so I thought it was good enough to use it
Old Dec 15, 2009 | 12:18 PM
You should always check cranks for bend before installing them. It's easy to do, just install the front and rear bearings and put a dial indicator on the center journal. Even .001" bend could cause the crank to bind.
Old Dec 17, 2009 | 11:34 PM
grjr's Avatar
it isn't normal... did you check for rotation before installing the pistons/rods? With only the crank installed and lubed up you should be able to spin the crank by hand with a few fingers on the nose of the crank.
Old Dec 18, 2009 | 09:37 AM
GSR_hatch936's Avatar
Umm did you use all the same main caps and in the right way pointing towards the timing belt? And by any chance did you miss match the rod caps?
Old Dec 18, 2009 | 08:59 PM
Psychoteen101's Avatar
Overtorqued?
Tyler Godley
Engine Machining & Assembly
10
Feb 24, 2019 07:49 AM
turboman2.2
Mar 28, 2010 08:22 PM
huge230
Feb 15, 2008 08:44 AM
lsvtec hatch05
Nov 29, 2003 06:19 AM
V8 BAIT
Jun 21, 2003 06:22 PM
