Problem
Old Dec 15, 2009 | 09:05 AM
88JDMmade's Avatar
Default Problem
1988 Honda CRX HF 1.5L D15B6
Will not start no signs of cranking either. starter and flywheel just spin over.
it is engaging and everything but the engine doesn't fire.
I have checked.
Starter
new battery (old one was dead) new tested very good.
Ground wiring
Power wires
(so it's not an electrical contact problem)
then I pulled the plugs and they are covered in oil and gas. I'm assuming it's the valve cover gasket.. But I just want to verify that this is what it is. and it's not something serious. I'm doubting its the piston rings. but I'm going to see tonight if I have any compression what so ever.
thanks for the help.
..Casey.
Old Dec 15, 2009 | 10:05 AM
DJYoshaBYD's Avatar
Default Re: Problem
do a compression test... your timing belt may have jumped timing..
and just FYI, cranking is when the engine is moving.. your engine IS cranking, but not starting..
its TOTALLY NOT THE STARTER if your motor turns.. the starts ONLY JOB is to move the engine, to start the firing process.. THATS ALL.. if the engine moves, the starter and battery are good enough to start the car
have you actually checked to see if there IS spark? like, have you taken a plug, and put it in the wire to check for spark? if not, i suggest you do so... lol
well, its probably not the piston rings, because you would have HELLA smoke coming out when it happened..
Im going to put my money on really low compression, because of a skipped timing belt.. Compression test, and check cam timing
Old Dec 16, 2009 | 05:01 PM
88JDMmade's Avatar
Default Re: Problem
pulled the plugs they were covered in oil. so i cleaned them up and installed a new valve cover gskt. i'm putting it back together tommarrow morning so I'll let you know then if she runs. should though.
Old Dec 16, 2009 | 11:24 PM
hatchet_honda's Avatar
Default Re: Problem
if the plugs covered in fuel...my bet is you have no sparky my friend
Old Dec 17, 2009 | 06:47 AM
88JDMmade's Avatar
Default Re: Problem
I put in the new plugs changed the gaskt. but umm... it turn the key.. starter is spining and engaging.. but cam sprocket hardly even moves if it does it's like 1/8 turn every now and then... could my dumbass friend have put something together wrong in the clutch assembly when he put it on? this is really not making me happy. guess I'll make sure there is fuel and that all the fluid levels are good.they should be though.
Old Dec 17, 2009 | 07:19 AM
jlicrx's Avatar
Default Re: Problem
sounds like it doesn't have a woodruff key holding the timing belt gear to the crankshaft or the key is broken
sasinorm01
Jul 18, 2018 04:07 AM
ge_itr
Dec 8, 2006 10:13 AM
blusmke
Dec 1, 2004 10:02 PM
Drian
Nov 29, 2004 08:31 AM
ls_vtec_b18a1
Nov 4, 2002 07:12 PM
