thermostat help 94 integra
Old Dec 14, 2009 | 11:39 PM
KaiKasei's Avatar
Default thermostat help 94 integra
Alright so here's the deal. I got a 94 integra ls and when I bought it the engine temp was always on cold no matter how long I drove it. Thermostat right? So I thought that the thermostat had one of those fail safes that keep the thermostat open for coolant to go through and keep the engine from overheating. I changed the thermostat and the engine overheats and at the same time the car's idle goes crazy it idles vigoriously, wasn't like that before. When I give it a test drive I noticed my car wants to speed up very slowly by it self and when I'm at a complete stop the car keeps jumping forward and I do notice the rpm keeps going up and down when I'm at a complete stop. One possibility that I came up with is that the radiator fan doesn't come on when the temperature goes up. I'm just seeing if just this radiator fix will fix the whole crap that came with changing the dam thermostat.
Old Dec 15, 2009 | 12:31 AM
jdmtom's Avatar
Default Re: thermostat help 94 integra
x2
my girls dc doesnt overheat but will never get warm. stays at cold and temp never rises by normal unless it idles for about 5-10 mins in when sitting.
whats good hondatech??
Old Dec 15, 2009 | 01:34 PM
THEUSED's Avatar
Sounds like you may have some air in the cooling system, try bleeding it some more
Old Dec 15, 2009 | 04:26 PM
VTECJUN's Avatar
When the car is overheating is the lower radiator hose hot or cold? When you say that you replaced the thermostat what brand/style did you get. Reason I ask that question is there are some cheap thermostats that always have issues right out of the box. Another thing to check is the radiator. Can you feel the radiator when the car is running. You should check to see if the coolant is circulating all the way through top to bottom of the radiator, it should be warm at the top and the bottom if it is working properly when the thermostat is open.
thegatekeeper14
Dec 13, 2009 09:25 AM
vlude99
Jul 30, 2009 05:58 PM
JAYDmManny1331
Jul 23, 2009 07:43 AM
jsnmullis
Feb 11, 2009 08:55 AM
vdawg559
Apr 7, 2008 04:27 PM
