DC 4-1 or 4-2-1 for 97 GSR?
Old Sep 2, 2002 | 09:49 PM
Jt240's Avatar
Default DC 4-1 or 4-2-1 for 97 GSR?
Websites say 4-1 gives more power from 4K+ w/o losing any bottom end and 4-2-1 gives more low end power and torque? Who actually has a GSR and have experienced either and what are your inputs? I'm running a stock motor w/ stock redline, so no crazy 10k redline yet.. Any help would be great.
Old Sep 2, 2002 | 09:52 PM
The Rob's Avatar
Default Re: DC 4-1 or 4-2-1 for 97 GSR? (Jt240)
The 4-2-1 will give like a 1hp gain down in the bottom with most of the gain in the mid. The 4-1 will give a decent gain up top (6k+) but you might possibly lose lowend. That being said, unless you are going for a 4-2-1 hybrid (Hytech) then I say go for the 4-1, especially on a GSR.
Old Sep 2, 2002 | 10:56 PM
BoostCreeper's Avatar
I would go with the 4 2 1 design because you dont want to lose any low end grunt if possible and the 4 into 1 design is cool only when your pushing cams and lots of air.
Old Sep 2, 2002 | 10:57 PM
vtecdc2's Avatar
Default Re: DC 4-1 or 4-2-1 for 97 GSR? (BoostCreeper)
i'm running the 4-2-1 because its not often i'm driving above 6k rpm
Old Sep 3, 2002 | 12:19 AM
vteg's Avatar
New User
Default Re: DC 4-1 or 4-2-1 for 97 GSR? (VTECDC2)
I have the 4-1. I had no loses over stock. This shows up on my dyno also. Unfortunately between dynos I did both header and exhaust.
Old Sep 3, 2002 | 12:42 AM
Anthony K's Avatar
New User
Default Re: DC 4-1 or 4-2-1 for 97 GSR? (vteg)
4-2-1
Old Sep 3, 2002 | 01:07 AM
Hapa DC5's Avatar
Default Re: DC 4-1 or 4-2-1 for 97 GSR? (Anthony K)
4-1 if you plan on doing some major NA stuff later. 4-2-1 if it's daily driven and really don't plan on modifying it past basic bolt ons.
Old Sep 3, 2002 | 06:25 AM
1.8monster's Avatar
just get the 4-1. our little 4 cylinders aren't made for the bottom end power so we have to catch up on the top end. the 4-1 header has great top end. im not sure where i read this but it gave like 10 wheel horsepower at the top end. and no im not a dumb lil kid that believes everything i read. i have actually felt a huge difference in the top end on that header.
Old Sep 3, 2002 | 06:27 AM
Stewie's Avatar
Default Re: DC 4-1 or 4-2-1 for 97 GSR? (1.8monster)
jdm dc
Old Sep 3, 2002 | 06:43 AM
StyleTEG's Avatar
Default Re: DC 4-1 or 4-2-1 for 97 GSR? (Mac8008)
http://www.automotiveperformanceengi...om/header.html
Not a huge difference between the 4-2-1 and 4-1 headers tested there.
[Modified by StyleTEG, 3:43 PM 9/3/2002]
Old Sep 3, 2002 | 06:51 AM
au-gsr's Avatar
anh you're all pointin this guy in the 4-1 direction, why?
no ground clearance=more dents and constricted airflow
if he's askin bout headers he'll probably go with exhaust and intake so a 4-1 will not net any gains until those other options are installed and will only produce minimal gains over a good 421 unless he spends some duckets on tuning the thing.
maybe itts gonna be a track car but then again it amy be a daily driver
4-1 is great if you have the supercharger/extremely modded NA idea goin in your head and have all the other components bolted on already.
personnally i would go for a 4-2-1 design. more midrange and improved top-end beacuse of the better flow design. if some one will post the great header test for this guy , i'm sure all the answeres that he would have questions for could be found there.
dude go 4-2-1 get a comptech, they are torque stepped to improve the midrange(2500-5000) and they produce just about as much power as all the 4-1's out there.
DC sports headers crack!! so i'd stray away form them, cermaic rusts fast too!!
if you dgo JDM you'll need to modify your cat or get a new one because the collector on the JDM pipes is 2.5" compared to stock 2.25 for gsr's.
Old Sep 3, 2002 | 07:28 AM
neo1z's Avatar
bottom line --- if youre going 4-2-1, get a comptech.
Old Sep 3, 2002 | 09:12 AM
vteg's Avatar
New User
Default Re: DC 4-1 or 4-2-1 for 97 GSR? (au-gsr)
If you get JDM get a new cat also, since the stock one is 2 inches internally.
R-gonaut's Avatar
Default Re: DC 4-1 or 4-2-1 for 97 GSR? (neo1z)
my 4-1 scapes like a ****...
go 4-2-1. Comptech SS
Old Sep 3, 2002 | 11:49 AM
illi Adik's Avatar
go jdm 4-1 and carsound cat, great matchup
Old Sep 3, 2002 | 01:46 PM
au-gsr's Avatar
Default Re: DC 4-1 or 4-2-1 for 97 GSR? (Jackson4Door)
why the car will have no low end and it will suck as a daily driver. go with the comptech the amount of time you sp[end replacing your 4-1 headers becasue they are dented or cracked from speed bumps is not worth it.
Old Sep 4, 2002 | 05:00 AM
:jdmshmaydm:'s Avatar
Get a 4-1. Everyone knows that GS-R's are good in top end. So make a good thing even better. The car has a strong point so make it stronger. As far as scraping and what not, buy a skid plate. They have those for 4-1 header. And as far as losing low end torque and power, launch on drag radials while bouncing off the rev! Jk
atmosphere
11
Apr 12, 2006 03:53 PM
jt-sport
Aug 26, 2003 03:57 PM
Brett
Nov 10, 2002 12:46 PM
D16Z6racing
Aug 2, 2002 09:09 PM
Gerst240
Jun 5, 2002 08:36 PM
