95 Accord Help
Is the heater the only thing that stays on? Also have there been any repairs or modifications done to this car recently? Do you have any other issues starting the car? We need more info than just the heat stays on when u turn the car off.
yes the heater is the only thing that stays on and recently i did a complete tune up and replaced my distributor starter and speed sensor and my car acts like it doesnt wanna start some times because my dumb *** brother cranked it while dad distributor was off of it but im guess dats a timing problem
I know the ignition control module is tucked up into that area you were working in with regard to the distributor. I would look around that area for damaged components and Ign module that's been polarized ir busted/stuck open will continue to drain the battery even if the car is off. At least that's what happened to my car. That wouldn't explain the heater per say but i'm wagering the distributor area is where you should start looking.
1badcrx
May 18, 2009 01:21 PM
BurgAccord95
Jan 5, 2007 04:49 PM
BurgAccord95
Jan 3, 2007 06:40 PM
