How To Install a Swoosh Voltage Gauge?
Hey guys, just bought a Swoosh volt gauge, model SA58, and I am completely lost!! How do I install this thing? At first I thought it connected to the batter but apparently it doesn't. Any help is greatly appreciated!!!
Run the power wire to a source that switches on with the ignition, such as a radio remote turn on.
I assume that you tried it to the battery and it stayed powered on. you can do that, but you'll want a toggle switch as it will just read the battery volts constantly.
No idea what a "swoosh" volt gauge is though. That may, though not likely, make a difference in how you wire it up. Waht did the directions say?
Here is exactly what I've got.
http://www.youtube.com/watch?v=R30sRRT0Vzk
What voltage are you trying to measure? If you just want to see what your accessories are running on you can access the voltage from the inner fuse box panel.
*Edit* And if you do that I would recommend going to the junkyard and cutting off some of the single wire connectors for the fuse box so it looks cleaner
it's what I did for my alarm install.
In that fuse block there is
- constant 12V
- 12V when turned on
- 12V when lights turned on
So you probably want the 12V when turned on, I'm not sure which is where position wise, all you need is a light tester to check.
- constant 12V
Still pretty confused, do you mean the fuse block as in the fuses under the hood? I don't even think the wires will reach that far.
OK! This gauge is a pain to install!!
Here is what the directions/description say, there really are no directions.
Red Wire - Battery +
Black Wire - Ground.
Orange Wire - ON, the car power line that will not be disconnected at start of engine, from key switch
Yellow Wire - ACC, from key switch.
Brown - Small Lamp
Brown - Small Lamp
the second reply is the answer here....connect the power wire to a source that comes on when the car does and not a constant source. the ground is obvious, and the illumination can be tied into your parking lights, so that the light only comes on at night.
Well what I did was tie the RED power cable to the battery and have the BLACK wire grounded, as mentioned above, the gauge is now on 24/7... I bought a switch but haven't properly installed it yet. I'm thinking about just trying to find an alternate power source that turns on when the car is on.
u should have gottin a groundin kit....
try this https://honda-tech.com/forums/forced-induction-16/need-help-wiring-swoosh-gauge-manual-pic-included-1797014/
try this https://honda-tech.com/forums/showthread.php?t=1797014
I wired the gauge to the battery and have a switch by the dead pedal, it looks pretty cool and works well, but is relatively useless.
92integraVTECgsr
Feb 22, 2018 08:33 AM
