best rpm to set vtec at on a typer p28?
i have to order a ecu again, due to the fact mine went bad somehow..
anyways it says the one im gonna buy vtec is set at 5,600. whats the lowest i can go for a stock b18c5 engine..? could i do 5,000 and still be reliable?
1000rpms is the awesomeness..jk
mine is at 5k but my motor is probley set dif then yours
but 5k seems just right to.
(gsr low comp, turbo)
a stock ITR will likely loose power if you set it to 5k, 5200 is the lowest I'd go unless you have it tuned specifically for the lower point.
IMO a basemap should start with a 5400-5600 VTEC point and tuned from there.
Exactly. I have my vtec kicking in at 3k. JRSC'd D16 tuned with a s300 by me. As long as you know what you are doing tuning-wise, you should be fine.
well i just assumed leave it at wht they put it at(5,600) i dont plan on keeping the c5 in it that long anyways just the daily motor so i can build my gsr out of the car for turbo
Your vtec point on a stock b18c5 really depends on your exhaust/intake setup as well as how well your ecu is tuned etc.
We have tuned type-r motors with toda style headers & a short ram intake with vtec at 4800 rpms. Then we have seen some with stock exhaust/headers & intake boxes like vtec at a higher point such as 5,500 rpms.
One old school example:
BlackRocket
Jun 11, 2005 10:56 AM
