jerking/surging
Old Dec 9, 2009 | 09:39 PM
bam_89's Avatar
Default jerking/surging
hey guys i have a b16 that i recently built. everything checks out except it is throwing the tps code 7. the throttle body came with a brand new tps so i know the sensor is good, jw if it will throw the code due to it not being calibrated correctly? thnx
Old Dec 10, 2009 | 11:20 AM
delsolproblems's Avatar
Default Re: jerking/surging
I don't think you get that code unless there's no signal from the TPS. Check the TPS voltages with the engine off and the key in the on position.
Old Dec 10, 2009 | 09:44 PM
bam_89's Avatar
thanks man, it was actually my tb had a leak on it, so i switched tb's and it fine.
rhdins
Jul 20, 2008 05:12 AM
ALLshowNOgoLS
May 4, 2006 02:19 PM
TegLove
Apr 23, 2004 11:24 AM
type Gendy
Mar 7, 2003 10:12 AM
