Window Problem
Old Dec 9, 2009 | 08:48 PM
EdWord's Avatar
Default Window Problem
My power windows roll up and down but just really slow, and sometimes when its cold or hot it tends to stop halfway and i would have to roll it up and go down to get it all the way down. Do i need to lube it? or do i need new regulators? Thanks
Old Dec 9, 2009 | 09:06 PM
gwl's Avatar
gwl
Default Re: Window Problem
Shoot some silicone spray around the front and rear edge of the glass.
Old Dec 9, 2009 | 09:56 PM
EdWord's Avatar
should i take off my door panels to do that?
Old Dec 9, 2009 | 10:01 PM
Former User's Avatar
No. Just roll the windows all the way down and spray the silicone lubricant down both rubber side channels.
Old Dec 9, 2009 | 10:20 PM
93delslow315's Avatar
i also had this problem and i tried the silicone lubricant and it worked great
Old Dec 10, 2009 | 06:48 AM
EdWord's Avatar
any ideas where i can get some silicone spray? home depot im guessing?
Old Dec 10, 2009 | 06:57 AM
Sleeper95ej's Avatar
Any Automotive/building supply should have it
Old Dec 10, 2009 | 07:01 AM
Even Walmart has it.
Old Dec 10, 2009 | 07:26 AM
itsnotfast's Avatar
I have the same problem. I'm going to try this tonight.
Old Dec 10, 2009 | 09:24 AM
love_my_ekcoupe's Avatar
I try this already n it doesn't work I even try taking of the window n I put it back to. Normal n is all good but bthen it comes of track
Old Dec 10, 2009 | 09:46 AM
supersize's Avatar
u need a new regulator... the silicone works for about a day.. get a new window regulator
Old Dec 10, 2009 | 10:16 AM
itsnotfast's Avatar
My window comes down straight most of the time but sometimes it gets wedged. The front goes down less than the back does. When going up the front always goes up a little less than the back of the wondow. When it's all the way up the back of the window is closed tight and the front has like a 1/4 inch gap. I've tired taking it apart and re-adjusting the front slide but no matter what I do it does the same thing. This can't be the regulator.
Old Dec 10, 2009 | 11:03 AM
David12's Avatar
the track is probably missalined, could be from someone trying to steal your car.
Old Dec 10, 2009 | 07:21 PM
!Ev0$'s Avatar
yeah i have the same thing
idk if somebody try 2 take my car but u never know
Old Dec 10, 2009 | 07:25 PM
GNUdreams's Avatar
I always have a problem with my driver side window as well. I work at 5am and when I roll the window down to open my work gates, it gets derailed from its track maybe 1 out of 20 times on its way back up. It lookes like the rubber side channels bind againgst the window when it comes up. I don't know how this would throw the window off the track, but mine tends to come off frequently
Old Dec 10, 2009 | 09:44 PM
EdWord's Avatar
I tried the silicone spray and my windows rolls up and down way smoother. But its still a little slow, I guess its time for new regulators.
phong3992
20
Mar 4, 2011 01:29 AM
OriginalFive
Honda S2000
May 3, 2006 10:11 AM
g2man
Feb 12, 2004 02:31 AM
Yellb16crxsi
Mar 5, 2003 04:39 PM
