puzzled?
Old Dec 8, 2009 | 05:17 PM
sloaccord97's Avatar
Icon2 puzzled?
i had my 97 accord lx converted to 5 speed and now my car idles up and down. im still running my auto computer for know til i can find one for a standard.ive tried to to find a vacuum line off but no luck. i may be over looking one but i need help on fixing my problem.
Old Dec 8, 2009 | 08:04 PM
srmofo's Avatar
Default Re: puzzled?
did you unhook any coolant lines? if so you need to bleed the system, and in paticular the idla air control valve (iac). do a search, theres plenty of info on it.
spray carb cleaner when looking for a vacuum leak. the idle will change when youve found it
Old Dec 9, 2009 | 09:54 AM
would using my auto ecu cause it to do that?i will also try to bleed my cooling system.
Old Dec 9, 2009 | 04:33 PM
srmofo's Avatar
lots of wierd things can happen when using the wrong ecu however, that is very common problem and you should check the obvious first
Old Dec 10, 2009 | 01:47 PM
delsolproblems's Avatar
When did it start? What RPM's does it bounce between? About how quickly is the RPM bouncing? Does it struggle or miss at any times? Are there any times it idles fine, better or worse?
Old Dec 11, 2009 | 04:39 PM
its done it since the swap was done and it bounces between 1 grand and 2200. it almost acts like a vacuum line but it could also be ecu. if it is i cant find one anywhere.
Old Dec 11, 2009 | 08:02 PM
You can check the MAP sensor voltage. If it's working properly, it'll tell you how much vacuum you're making.
1kleenef
Sep 29, 2007 07:39 AM
redpeppers
Jul 26, 2005 05:10 AM
galioth
Oct 28, 2004 03:47 PM
Endless STi
Oct 19, 2004 02:45 PM
