Bad CEL.. Random Missfire all 4
Old Dec 7, 2009 | 09:01 PM
thanh4o8's Avatar
Default Bad CEL.. Random Missfire all 4
Car is OBD2B btw. I was on the way home going up a hill so i downshift to 3rd and took it to 7k on a gsr then went to 4th and took it to 6 before letting off. CEL started blinking. exit the freeway and pulled into a parking lot. on the way, car dies while coasting. started it when parked and it sounds like its misfiring real bad. rpm drops real low. had to keep light throttle to keep the car running. replaced plugs and wires. Cap and Rotor Still good. Pulled ECU code and got misfire for all 4 cylinder. I am really confused now.. Any help will be appreciated.
EDIT: Forgot to mention car has no knocking sounds and it drives fine pass 3k rpm.
Old Dec 8, 2009 | 10:10 AM
delsolproblems's Avatar
Default Re: Bad CEL.. Random Missfire all 4
Is your coolant reservoir bubbling when the car is running? Are you overheating? If not, check the air and fuel filters, check the grounds, check ignition timing, check for spark, and then the fuel pressure.
Old Dec 8, 2009 | 08:20 PM
thanh4o8's Avatar
no over heating.. air and fuel filter is new. grounds all good. i will check ignition timing tmr and there are sparks. how do i get fuel pressure
Old Dec 9, 2009 | 08:26 AM
Go to a parts store and get a loaner fuel pressure gauge. You'll probably have to put down a decent sized deposit but you'll get it back. If the ignition timing is suddenly way off, don't try to fix it yet. Take off the valve and timing covers and see if the belt slipped.
Old Dec 9, 2009 | 08:39 AM
You can connect the gauge to the service port on the fuel filter.
Old Dec 9, 2009 | 01:12 PM
thanh4o8's Avatar
wheres the service port?
Old Dec 10, 2009 | 11:28 AM
It's a bolt that goes into a larger bolt that screws the fuel line onto the filter. You take the smaller bolt off, the larger bolt still holds the fuel line to the filter and the gauge screws into the larger bolt. Some vehicles have a service port on the fuel rail itself.
justlivinlife85
Honda CR-V & Element
Apr 29, 2016 02:29 PM
MidnightGSR591
Sep 12, 2011 11:47 AM
OhWUNshlude
Nov 29, 2007 09:37 PM
BrownGSR
Apr 2, 2003 10:30 PM
Buckshot
Jul 30, 2002 10:14 PM
