Gsr Cel Codes
Old Sep 11, 2011 | 10:54 PM
MidnightGSR591's Avatar
Default Gsr Cel Codes
Hello, i've been researching this for months and still have never come to a proper solution and closure to this particular problem.
p0301 -- cyl 1
p0302 -- cyl 2
p1300 -- random misfire
p1399 -- any cyl misfire
Already checked, timing, ignition timing, cam timing, new plugs, new wires, valve adj, fuel filter
have not checked rotor or cap, i know there is someone that had these sames problems, whether it was a vacuum leak or something even simpler, bad ground whatever. if any one has any info lmk, anything would be appreciated, thanks
Old Sep 11, 2011 | 10:58 PM
Lsvsmoker's Avatar
Default Re: Gsr Cel Codes
Try checking the fuel source, a weak fuel pump or restricted lines can cause misfires.
Old Sep 11, 2011 | 11:02 PM
these will be throwing codes as well? Is there anyway to narrow down a bad fuel source before i start tearing down lines?
Old Sep 11, 2011 | 11:05 PM
Lsvsmoker's Avatar
Fuel pressure tester, I'm not sure what the spec are but that's the easiest way to check for fuel problems.
Old Sep 11, 2011 | 11:10 PM
Will check that, thanks for the input, back to top
Old Sep 12, 2011 | 11:26 AM
***UPDATES
Was unable to do a fuel pressure test, but went ahead and did a compression test here is my results
cylinder 1 - 200
cylinder 2 - 90
cylinder 3 - 200
cylinder 4 - 200
Assuming there is nothing wrong with the valve, i'll go ahead and try a valve adj first, 110 pounds loss is a very big loss though. Will post updates and see how it goes
Old Sep 12, 2011 | 11:35 AM
Lsvsmoker's Avatar
yeah try adjusting the valve first since thats the easiset thing to do first. your try doin the wet compression test to see if #2 goes up??
Old Sep 12, 2011 | 11:47 AM
no not today i will not be doing that, letting the car cool off a couple hours before adj
eternaltech
Nov 5, 2012 09:07 PM
96 EX
12
Jul 3, 2008 05:33 PM
pr_tony_montana
May 27, 2005 01:09 AM
Vinny97lude
Apr 16, 2004 06:02 AM
civicspeed77
May 27, 2003 12:13 PM
