Stick Shift Vibration
it's called a rod shifter linkage. welcome to honda's (except for the cursed k series).
jack your car up, throw it on jack stands, get under there and have someone move the shifter around. you will see a bar just above the exhaust system that goes directly the tranny.
bottom line, the shifter is directly connected to the engine and the engine vibrates.
oh ok, cause i used to own a rsx-s, and i didn't feel this much rattle. i mean, it's not unbearable, i just thought it wasn't normal coming from my rsx.
how much are new bushings?
btw, thanks for the quick input, you guys are hella chill.
Definitely spring for some Energy Suspension bushings. They make shifting a heck of a lot more precise. I actually notices a little more vibration while my hand was on the shifter, but the shifter stayed still more with my hand off it. There's less play and the bushings are firmer...
Heres some ES bushings for a 99 Civic(Non-Si). Can get them in Blk/Red. $8.99 plus S/H. Even if it don't cut down to much on vibration if it will make the gear shifter feel more precise and consistent like Thumper said then IMO its worth it for sure.
http://www.energysuspensionparts.com...prod=16%2E1102
erikiksaz1
Mar 28, 2005 01:51 PM
