Jumping Idle
Old Dec 7, 2009 | 04:24 PM
hammergunner's Avatar
Default Jumping Idle
my idle in my 94 del sol keeps jumping for 1000 to 3000
its a b16a motor, and i've replaced the IACV what else effects the idle
Old Dec 7, 2009 | 04:40 PM
wshuculd's Avatar
Default Re: Jumping Idle
Its probably your fast idle valve.
Old Dec 7, 2009 | 04:47 PM
there is no fast idle Value on this manifold
could it be any other sensors that are making it ldle wired
i also replaced the Head gasket,manifold gasket and the throttle body gasket
so i know im not leaking any vacuum
Old Dec 7, 2009 | 05:18 PM
wshuculd's Avatar
Take brake cleaner spray it on your gaskets and hoses anywhere it could have a leak.If its leaking when you spray it on there it should idle fine
Old Dec 7, 2009 | 05:22 PM
i've checked all the vacuum lines and nothing is leaking, still crazy ldle
anyone got any clues?
Old Dec 7, 2009 | 05:35 PM
FlatBlkEk's Avatar
Ive seen felpro manifold gaskets fail after doing head gaskets so after the first couple i seen with vacuum leaks i started using honda intake manifold gaskets only, torqued to spec btw . Spray carb clean on the gasket (between the manifold and head...) and also on the tb if you come up with nothing take it all apart and have a look maybe you made a mistake on the install. Nobody is perfect....
Live and learn
Let me know the outcome of what ya found
Old Dec 7, 2009 | 05:40 PM
cool will tear down the motor tonight, and see whats happening to the gasket
Old Dec 9, 2009 | 10:13 AM
FlatBlkEk's Avatar
status?
apbtwhiskey
Apr 5, 2013 01:51 PM
93SiPrelude
Feb 24, 2008 10:39 PM
saikouEF8
Jun 15, 2006 04:31 AM
loudassVTEC
Oct 5, 2005 10:40 PM
rtiadnoh
Feb 15, 2004 12:41 PM
