Obd2 to Obd1 Question...TPS/Injectors Related.
Old 12-08-2009, 09:16 AM
T9U4ReBgO's Avatar
Default Obd2 to Obd1 Question...TPS/Injectors Related.
1997 Civic CX...
So my car is completly converted, runs, drives, everything. Just with the car off, key to run position to check codes there are none.
Start the car, it then throws a 7 TPS sensor code. Okay so I have my stock OBD2 injectors in, would that be the problem? Thats the only thing thats still OBD2. Running a stock P28.
Also it has really bad throttle response because of the TPS sensor.
Old 12-08-2009, 10:24 AM
civic_r87111's Avatar
Default Re: Obd2 to Obd1 Question...TPS/Injectors Related.
If it's throwing the TPS code then something is wrong with the TPS inspect the sensor and wiring and replace or repair.
Old 12-08-2009, 10:35 AM
T9U4ReBgO's Avatar
TPS has been switched. Wiring is fine. Only throws TPS code after the car starts.
Old 12-08-2009, 03:57 PM
Anon51's Avatar
is the tps adjusted properly? its supposed to be .45-.50v closed.
Old 12-08-2009, 05:21 PM
T9U4ReBgO's Avatar
Fixed, it was the OBD2 injectors.
Old 12-09-2009, 10:26 AM
Ok, how did the injectors cause the TPS code?? The resistance in the OBD1 and OBD2 injectors r the same.
Old 12-09-2009, 10:29 AM
DCRB's Avatar
it's possible that in replacing the injectors he may have "bumped" or wiggled w/e was throwing the code to the tps, causing it to fix it's self
Old 12-09-2009, 10:39 AM
True but strange
TeknikDC2
01-25-2010 08:56 PM
sageuvagony
09-22-2008 12:47 AM
eg6_rick
02-23-2005 05:20 PM
Boost2NA
08-29-2004 08:15 PM
Quick Reply: Obd2 to Obd1 Question...TPS/Injectors Related.
