Suspension & Brakes Theory, alignment, spring rates....
brake bleeding problem
Old Dec 7, 2009 | 01:24 PM
red96civicex's Avatar
Icon2 brake bleeding problem
i think i figured it out!
Old Dec 7, 2009 | 06:37 PM
Default Re: brake bleeding problem
am i using the wrong fluid or something? ive used it before..
Old Dec 7, 2009 | 08:36 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
did you change out the master cylinder? or prop valve?
Old Dec 7, 2009 | 08:37 PM
bleed procedure should be : RR,LF,LR,RF
Old Dec 8, 2009 | 05:15 AM
no
and thats the way i was doing it...
Old Dec 8, 2009 | 06:18 AM
the lines must've gone completely dry, as did the prop valve.. just keep pumping the pedal with all the bleeder screws shut then try the pumping procedure again until you get fluid
Old Dec 8, 2009 | 06:33 AM
tienzien's Avatar
when you bleed it, do u use a clear tubing line to show that the stream is solid with no air bubbles?
Old Dec 8, 2009 | 07:06 AM
for sure, the car was sitting for a few days without any suspension on it. thanks
no, i just loosened to bleeder valves for about a second and fluid came squirting out then i closed it real fast. but i didnt see any air..
Old Dec 8, 2009 | 04:08 PM
ok so today i used a clear bottle and some tubing, i put the tubing over each bleeder valve and dipped the tip of the tubing into the clear bottle that had brake fluid in it, i bled each wheel 4 times, and did the whole process 3 times, which would make it 12 times for each wheel with NO luck. WTF.
Old Dec 11, 2009 | 09:18 PM
dleccord's Avatar
does anyone know that size of the tubing because im going to home depot to get me some heavy duty shist. the one you buy from autozone in that bleeder kit shrinks by the time you bleed the front two nipples.
oderfla90
12
Mar 15, 2017 04:58 PM
SiHatchTurbo
Aug 25, 2010 07:20 PM
BlitzSix
Nov 5, 2008 09:35 PM
mickey513
Dec 2, 2003 07:53 AM
Batoutahell
Apr 2, 2003 07:54 PM
