Civic putters just in wet weather???
Old Dec 6, 2009 | 09:44 AM
marc100's Avatar
Default Civic putters just in wet weather???
Okay guys my car only does this when it is raining out or snow..and when driving my car sort of putters...I coming out of first and it doesnt feel like it has power then when i sort of floor it..it doesnt go and then it kicks in randomly and goes quick back to normal? It does it in any gear.. It has new battery..new alternator if that helps.. 92 d16.
Old Dec 6, 2009 | 10:00 AM
Terrible One's Avatar
Default Re: Civic putters just in wet weather???
do you have a cold air intake? maybe it's drinking water lol or maybe you have a bad o2 sensor.
Old Dec 6, 2009 | 10:03 AM
marc100's Avatar
no, short ram intake..i never see water in the engine bay on parts...why bad o2 sensor?
Old Dec 6, 2009 | 11:05 AM
yankeefan855's Avatar
check your plug wires with it running spray some water on the wires it should sputter if thats the issue
Old Dec 6, 2009 | 11:09 AM
WeakSauce92's Avatar
like yankeefan855 said, spray some water around the wires in your engine bay.
Old Dec 6, 2009 | 11:19 AM
matt17249's Avatar
I would check the wires first but it sounds more like the O2 cause of the flooring the pedal. If the wires test fine then check operation of the O2
Old Dec 6, 2009 | 06:06 PM
supersize's Avatar
definatly sounds like the 02
Old Dec 6, 2009 | 06:44 PM
92lxsleeper's Avatar
see if the distributor cap seal is good. sometimes water can spary up in side of there, and also the TPS seal. my chevy 1500 did the same thing.
Old Dec 6, 2009 | 08:48 PM
forcefedferio's Avatar
my vote is spark plug wires, seen it a million times.
do a full tune-up, chances are if the wires are bad it could use it anyway.
Old Dec 7, 2009 | 03:13 AM
turbodtaylor's Avatar
Even if you have a SRI, if your splash guards aren't in place it could still be sucking in some water which throws off your MAF, had that problem before.
Old Dec 7, 2009 | 07:35 AM
even if you did have that problem before you didn't have it on a civic, integra, crx, or pretty much any honda.
Romo Pyro
11
Aug 15, 2008 07:48 PM
Achenar
12
Dec 30, 2005 09:17 PM
fraknstien
Oct 31, 2005 02:31 PM
runitup
May 2, 2004 10:02 PM
meccA's eg6
Sep 18, 2003 02:20 PM
