Ol Leak
Old Dec 5, 2009 | 11:51 PM
eg grom's Avatar
Icon6 Ol Leak
Wuddup Fellas,
So I'm lookin' to fix an oil leak problem I've got, but not sure where it's coming from. When I bought the car the original owner said that there was an oil leak around the distributor, but to be honest I have never heard of an oil leak from the distributor. Can anyone enlighten me on what he was actually talking about? Also, it seems that when you live in the middle of BUMF*%k nowhere it's impossible to buy a gasket for the vtec solenoid of a d16z6, anyone know a site where I can pick one up?
Old Dec 6, 2009 | 12:38 AM
Linked's Avatar
Default Re: Ol Leak
the seals in or by the dizzy can leak oil ( dunno exactly, its a common problem, i might have it)
but google, honda oem are your friends, there are other places
Old Dec 6, 2009 | 12:44 AM
94_DC's Avatar
Default Re: Ol Leak
Distributor leak is common but the only place you will get a replacment part ( O-ring) is a dealership. Try ebay just make sure its OEM.
Old Dec 6, 2009 | 06:55 AM
Former User's Avatar
Default Re: Ol Leak
You may be able to purchase a replacement O-ring for the distributor at your local auto parts store.
Old Dec 6, 2009 | 07:25 AM
92lxsleeper's Avatar
Default Re: Ol Leak
theres a seal inside the distributor, after you pull all the internals out you will see it.
i had the same problem when i did a b7 to z6 swap last year. i went through O rings and it was still leaking. i then pulled the dizzy cap off to find the inside of the distributor soaked in oil, so that told me that the internal seal had failed.
Old Dec 6, 2009 | 07:28 AM
Default Re: Ol Leak
distributor internal seal
http://www.autopartswarehouse.com/sk...%26+Drivetrain
Distributor O ring
Vtec solenoid gasket
distributor cap gasket
get it all, and your all set.
Old Dec 6, 2009 | 10:32 PM
boxeocampeon's Avatar
Default Re: Ol Leak
could be the distributor o ring or vtec solenoid gasket. pick them up at the honda dealership...if not then it could be the valve cover gasket
ronk123
Apr 18, 2017 01:01 AM
DeLSoLRo
Jun 10, 2013 06:32 AM
Cameron k.
60
Sep 25, 2012 07:19 PM
Paprika
19
Aug 4, 2006 08:19 AM
hatchbro
Oct 13, 2004 09:00 PM
