NEED URGENT HELP
So i was driving with my girlfriend in my 1994 honda civic hatchbak to a different town when half way through the trip i lose power in fourth gear and notice that the engine started shaking and puttering upon accelerationn. then when it idles after start it dies and when i stop anywhere at anytime it will stall......i took out all the sparkplugs and cleaned them and put them back in after a while it worked ok but then the problems came back....any suggestions as to resolve this problem?
haha....
Sounds exactly like the main fuel relay. While I'm not 100% on this one, I had this EXACT problem with my old 92 hatch. I wouldn't rush out to get a new one, but I would most definently get it tested with an ohm meter
It could also be spark related (Distributor). Ignition coil and igniter are the common things to go out as well. There are ways to check if these are bad just do a search for the test.
JasonST
15
Mar 10, 2022 08:46 PM
ill phil
Aug 23, 2003 06:18 PM
