gt35r ok running low boost?
Old Dec 4, 2009 | 07:58 AM
90Rexx's Avatar
Default gt35r ok running low boost?
Is it ok to run a GT35R 70ar compressor housing at less than 1 bar of boost? around 11 or 12 specifically? im looking at the compressor map and it says efficiency range is only above 1.5 bar. would this mean running at 12 psi would damage the CHRA from surge?
heres the link to Honeywells site for the compressor map
http://www.turbobygarrett.com/turbob...R_714568_2.htm
Old Dec 4, 2009 | 09:59 AM
YARO.'s Avatar
Default Re: gt35r ok running low boost?
No theirs no problem on running this turbo on low boost. Whats the setup and power goal?
Old Dec 4, 2009 | 10:57 AM
brian15's Avatar
I run mine on 7.8psi now .... with no plans to go over 12psi in the future.
Old Dec 4, 2009 | 01:23 PM
90Rexx's Avatar
goal is 400 whp on stock gsr engine on 93 octane. plan on turning boost down between 8-12 lbs. ( depending on how i feel that morning) for street use lol.
** i know a 35R is a bit big for my goals and it can be easily achieved on a smaller turbo, but i always like room to grow
Old Dec 4, 2009 | 04:24 PM
boostedcivicsir's Avatar
Mr. Badwrench
knowing that, you will be fine.
Old Dec 4, 2009 | 06:36 PM
omiehomie's Avatar
10 psi put down 345 whp on a stock gsr motor with ITR cams. and yes i have / need boost by gear, and yes i have traction problems
Old Dec 5, 2009 | 08:40 AM
boosted k20's Avatar
it will be fine. my ls/vtec put down 370whp on 10psi on a GT3582R T4
LSej1
Jul 19, 2008 03:51 AM
erikiksaz1
Jun 12, 2007 10:32 AM
turboegg
May 2, 2003 04:32 AM
sweettooth
Apr 27, 2002 08:33 AM
paulzy
Dec 5, 2001 10:04 AM
