ATP and Garrett have diff Compressor Maps for the GT28RS -- confusing!
Old Jun 12, 2007 | 09:33 AM
erikiksaz1's Avatar
Default ATP and Garrett have diff Compressor Maps for the GT28RS -- confusing!
First of all, my specs:
WOT - 8400
PR = 1.41
25 lb/min
75% RPM - 6300
PR= 1.41
18.85 lb/min
50% RPM - 4200
PR = 1.41
12.57 lb/min
Here's Garrett's compressor map for the disco potato:
And here's the map from ATP TURBO, note the Garrett watermark:
What the hell's going on? My numbers fall well into Garrett's own compressor map, yet my full throttle data falls off the chart for ATP turbos's.
Old Jun 12, 2007 | 09:40 AM
tony1's Avatar
Default Re: ATP and Garrett have diff Compressor Maps for the GT28RS -- confusing! (erikiksaz1)
How much boost do you plan to run?
Old Jun 12, 2007 | 09:55 AM
erikiksaz1's Avatar
Default Re: ATP and Garrett have diff Compressor Maps for the GT28RS -- confusing! (tony1)
I was planning on about 5-6 lbs of boost, whichever would allow for my goal of about 250whp.
The above pressure ratio was calculated with 6 psi though, using the methods we have in our FAQ.
Old Jun 12, 2007 | 10:29 AM
tony1's Avatar
ok, just making sure you were doing the PR calcs right. Alot of people think 1.4 is 1.4 bar of boost.
Old Jun 12, 2007 | 10:32 AM
erikiksaz1's Avatar
edit
Alrighty, I used Garrett's guide, and the numbers turned out to be slightly different. Compared to our FAQ's method of computing all this stuff, Garrett includes correction for things like pressure loss in the intake system.
My Numbers now:
Corrected PR - 2.16
27.56 lb/min @ WOT
23.22 lb/min @ Max Torque (5500rpm-ish)
These numbers fall beautifully into the potato's map.
Modified by erikiksaz1 at 5:36 PM 6/12/2007
thewrai6th
Jun 14, 2017 09:46 AM
Boyle.R
Dec 16, 2012 11:59 AM
90Rexx
Dec 5, 2009 08:40 AM
2LiterTurboSeR
Nov 11, 2005 03:26 PM
sweettooth
Apr 27, 2002 08:33 AM
