K20A2 BENT VALVE
Old Dec 4, 2009 | 03:56 AM
DIABOLIC8's Avatar
Default K20A2 BENT VALVE
So here's the problem, a buddy of mine just picked up a k20a2 swap with a bent valve. Unfotunately he met up with the guy and doesn't have any paper work, so he really doesn't have much of a dispute to give the guy because he just might deny everything. Well anyway we took the manifold off and saw one of the intake valves was bent a bit. Not to long after that i decided to look at the spark plug just in case, so sure enough the thing is smashed in. I've never delt with a bent valve issue/ smashed plug, so I don't know what to expect when helping him taking it apart. Can that issue completely demolish the internals of the motor? I'm hoping that the motor itself is still usable but I want to see if anyone has had a similar problem and what you found out once you took it apart. Thanks
Old Mar 27, 2010 | 11:18 AM
DIABOLIC8's Avatar
Default Re: K20A2 BENT VALVE
ANYTHING?
Old Mar 27, 2010 | 11:57 AM
nsxter's Avatar
the piston could be done or the combustion chamber of the head could also be done
Old Mar 27, 2010 | 12:07 PM
b18bringsHavoc's Avatar
What Mods have been done to the engine previously...If the head was milled un-properly that could have caused the problem, I would assume the piston has sever damage considering the plug was smashed. Just my assumption, but lets here from more experienced feedback...
Old Mar 28, 2010 | 07:40 AM
KWayRacing's Avatar
Sounds like misshift damage. Anyway, You will have to remove head for inspection. Smashed plug sounds bad though. This motor might be trash. Hope not
Old Mar 28, 2010 | 10:05 AM
pk386's Avatar
only way to tell is pull the head off and see.
(or a fiber optic camera through the spark plug hole, but not many people have those just laying around hehe)
If the spark plug is smashed up I'll the head snapped off the valve and tore up the combustion chamber. That will make the head and the piston trash. the piston skirt may be torn up but I think you can have a machine shop resleave it... (can you do that to a K20?)
SOHC_me
Jul 15, 2007 04:28 AM
rob2_0_0_5
Oct 1, 2005 02:28 PM
whatVTEC
Jun 26, 2005 08:33 PM
legendboy
Mar 11, 2004 08:59 PM
