car wont start
i have an ls. i replaced the water pump and timing belt and now my car wont start for some reason. i also replaced the spark plugs and rotor and cap. still wont start. it turns over just fine and im 99 percent sure my timing belt is on right. i think its getting fuel because i can smell it when try to start it a few times in a row. i also tried to use a couple skwirts of starting fluid and still nothing. i replaced my headgasket a while back because it was spitting out sweet smelling thick white smoke and my car started fine after i did that but since i replaced the timing belt and water pump it wont start now. can someone please help?
thanks,
michael
thanks,
michael
I would double check your timing belt... it sounds spark related if its not timing... you could be 180 off... i have done that before and it took me 2 days to figure it out and then bamm it hit me check my plug wires and sure enough I had them all screwed up and then it started right up!
ok i will check tomorrow
what game?
im pretty sure the timing belt is on right but i will double check.. i havent touched the spark plug wires since the engine started. so i dont think it would be that. but i'll double check on that too
ignitior?..
i'll make sure to check my spark and go from there
thanks for all the help everyone
what game?
ignitior?..
dam come on this had to happon to everyone in there life time, happoned to me in my si
after you do the water pump you have to turn it back to the factory TDC match up the marking's it should start up then re do the timing, happoned to me same symptoms smelt gas didnt start, cranks doesnt start but it still throw's a spark, o thats right becase its not in unicin with each other give it a shot it should work
and good luck p.s i know my spelling sucks
if anyone has anymore imput i would appriciate it
thanks
First check for spark, pull a plug wire, put a screwdriver into the end of it and put it close to a ground like a valve cover bolt and have someone crank it over, if there is no spark more than likely the coil went. That is what it sounds like to me, I've seen it more than I can count. If I had to bet money I would say 80% sure its a coil, or 20% ignitor, but more than likely the coil. Look at it and see if you can see any discolorization on the coil, such as blue or purplish rings.
Triple check that your cam/crank timing marks are lining up correctly since you just changed the timing belt. You want to be sure that your belt hasn't slipped a tooth or two which can happen if it isn't tensioned properly. If that is ok then next you want to double check that you placed the ignition wires in the correct sequence on the distributor cap. Either of these could be causing your no start problem. After you do get the motor running and warmed up it would also be a good idea to check your ignition timing as well. Good Luck!
im going to check today
thanks everyone for your help
i know you probably covered some or all of this but:
Get a compression gauge and check compression, so you can eliminate all this timing issue thing.
Did you get the water pump for you motor with correct number of teeth?
When you put your dizzy back together, and plugged the harness in, did you make sure the harness snapped back together- could be slightly not connected.
Firing order correct?
Tr0LL
Sep 24, 2008 04:40 AM
