Shift Problem Looked around can't find any answers..
Old Dec 2, 2009 | 12:58 PM
djw19842005's Avatar
Icon6 Shift Problem Looked around can't find any answers..
My 91 Integra feels like its in nuetral in all gears. (shifter moves from side to side in all gears) any ideas on the problem and how to fix it? Thanks for the help guys sorry if this is a repeat...
Old Dec 2, 2009 | 01:19 PM
ILS_09's Avatar
Default Re: Shift Problem Looked around can't find any answers..
Jack up the car and tighten the long bolt that goes through your shifting fork and the bottom of your shifter. But not so much though because the tighter you tighten it, the hard it is to put the car in gear.
Old Dec 2, 2009 | 01:33 PM
I tryed tightening it. still no luck??
Old Dec 2, 2009 | 04:40 PM
ILS_09's Avatar
u sure u tighten it correctly? cuzz if u tighten it with only a wrench or socket, the bolt will only spin in place
Old Dec 2, 2009 | 06:20 PM
seanbev24's Avatar
If tightening it doesn't fix the issue, the bushings are probably bad. Instead of replacing the bushings, I suggest upgrading to newer DC integra linkage, you will love it.
Old Dec 2, 2009 | 06:30 PM
honda_1's Avatar
its sounds like a motor mount is going to out my cousins integra had the same problem his bottom leftby the tranny went out and it felt loose in all gears like it was in neutral.
Old Dec 2, 2009 | 06:42 PM
95 integra's Avatar
Did you check to see if you have the 94+ clutch in your cable trans? The splines on the 94+ are larger and if you put a disc for the 94+ in a 90-93 then the input shaft spins inside the disc. It is "close enough" that if its in the air it will spin the tires, but whenever you put load on it, it will slip.
Old Dec 3, 2009 | 12:55 AM
honda_1's Avatar
does your shifter move like sideways during acceleration?
egsleeper
11
Jan 2, 2010 12:55 PM
DOUBLExDEUCEx22
Dec 19, 2009 01:25 PM
skUnK2jdm
11
Dec 13, 2008 11:43 PM
speedysohc
May 29, 2007 10:38 AM
AzntstyleZ
Jan 12, 2004 09:37 AM
