WHAT YOU GUYS THINK ABOUT THIS
Old Dec 2, 2009 | 12:20 PM
dc2luver's Avatar
Default WHAT YOU GUYS THINK ABOUT THIS
I WILL BE CHANGING THE VALVE SPRINGS. ALSO WILL INSTALL SOME CTR CAMS
B18b block
Golden Eagle Sleeve Guard welded in
Bored to 81.5
Cp 9.5 Pistons (have some 13.5 going with engine)
Callaro Rods
12.5lb. Act fly wheel
Toga high volume oil pump
stock crank
B16 head gasket from Honda
B16 head
gasket matched and polished
Ferrea Valves
Ferrea Valve locks
Crane racing valve springs
B16 cams
Billet cam seal
AEM timing gears
Greddy timing belt
Hondata intake gasket
B16 intake manifold
B16 throttlebody
RC 770cc injectors
AEM Fuel filter (red)
AEM fuel rail (red)
AEM fuel regulator (polished)
Mugen valve cover
Old Dec 2, 2009 | 01:27 PM
solo227's Avatar
Default Re: WHAT YOU GUYS THINK ABOUT THIS
Theres nothing to really think... The setup should be good for a decent amount of power...
Good luck Have Fun...
Old Dec 2, 2009 | 01:35 PM
azandford's Avatar
boost it til it blows
Old Dec 2, 2009 | 01:36 PM
azandford's Avatar
what are you tuning with?
Old Dec 2, 2009 | 03:30 PM
LTCxD2B's Avatar
ur gonna need a really good tune with that oil pump and vtec head
Old Dec 2, 2009 | 08:01 PM
project dc2's Avatar
get rid of the b16 cams get some ITRs CTR's, Blox stage 1, Type B, type C depending how big your setup is.
and get rid of that aem regulator and go aeromotive or something
and whats up with 13:5 comp ratio pistons ?
Old Dec 2, 2009 | 08:20 PM
pauld's Avatar
A Shopping list? Ive never understood this type of thread.... are you looking for someones approval?
Old Dec 3, 2009 | 04:05 AM
dc2luver's Avatar
that was a mistake
Old Dec 3, 2009 | 12:51 PM
dc2luver's Avatar
why you say that?
Old Dec 3, 2009 | 02:34 PM
LTCxD2B's Avatar
if the aftermarket oil pump pushes different pressures then stock vtec is triggered by oil pressure but thats what im told so it could cause some vtec problems
Old Dec 3, 2009 | 04:46 PM
turbociv910's Avatar
Old Dec 3, 2009 | 06:58 PM
pauld's Avatar
I want a "toga" oil pump too!
TOGA TOOOOGA TOGA TOOOOGA TOGA!!!!
Old Dec 4, 2009 | 03:33 AM
inspector01's Avatar
Fortunately you were told wrong. Vtec is not activated by oil pressure alone, or we would all have different vtec points.... Vtec is controlled by the computer activating a solenoid that then allows oil pressure to flow locking the rockers.
JDMCHICO
Feb 6, 2013 07:52 PM
jllong95
Sep 28, 2009 01:46 PM
civicmitch
Jun 4, 2009 10:28 PM
dookieK9
21
Apr 24, 2005 01:34 PM
sohcfreak
Sep 3, 2004 11:36 AM
