why when it rains my carpet is soked
Old Dec 1, 2009 | 10:20 PM
attica's Avatar
Default why when it rains my carpet is soked
my headliner also leak. but i dont know if thats the problem.how do i make my headliner stop leaking?
Old Dec 2, 2009 | 01:22 AM
crxcess's Avatar
Default Re: why when it rains my carpet is soked
deleted
Old Dec 2, 2009 | 01:46 AM
NACvicSi's Avatar
Check out my "build" thread. Mine was doing the same thing.
https://honda-tech.com/forums/appearance-build-threads-122/1990-crx-si-revival-2684632/
Old Dec 2, 2009 | 07:43 AM
EL Vap133's Avatar
Sit inside the car and have a friend run a water hose until you can spot the leak.
Old Dec 2, 2009 | 07:47 AM
scottmog's Avatar
best advise ever, dont guess where its coming from or just suspect the usual areas. find the area and test the usual areas.
Old Dec 2, 2009 | 08:41 AM
4drEF's Avatar
Keyboard Humorist
Take your carpet out... it's probably all moldy now =(
Old Dec 2, 2009 | 08:51 AM
0ne-Cam's Avatar
advice that im going to give you, find the hole and jbweld/silicone the **** out of it
Old Dec 2, 2009 | 12:28 PM
NACvicSi's Avatar
Hard to do when the leak is usually behind the "skeleton" on the roof. I just went through this.
Old Dec 2, 2009 | 02:48 PM
D16SiHatch's Avatar
or if its on underside of where the windshield sits. i had a leak and didnt find the hole until the cracked old windshield was out. and the area that was leaking was not visible from inside the car either even with the headliner pulled out of the way.
Old Dec 2, 2009 | 02:58 PM
KINGVEM^^ED6's Avatar
X2!
Old Dec 2, 2009 | 04:49 PM
Boost_Addict_88's Avatar
Check all of your weather stripping. It could be cracked and brittle from old age.
Old Dec 2, 2009 | 07:43 PM
EL Vap133's Avatar
Sometimes you can narrow it down depending on where the leak is at.
Old Dec 2, 2009 | 07:56 PM
Matt91's Avatar
That used to happen to my carpet too, didnt help that the windshield was basically smashed but, even when i got a new one it still leaked, figured out it was from where the antenna is outside the car. The gasket thing under it was basically gone.
Old Dec 2, 2009 | 09:18 PM
nitewolf's Avatar
most likely the windshield
87supraT
Apr 5, 2009 05:57 PM
john457
Mar 3, 2007 06:34 AM
project ak
Oct 5, 2006 04:44 PM
hbracer93
10
Jul 27, 2005 01:04 PM
DeadVet
Apr 7, 2005 05:44 PM
