Cometic head gasket leaking
my cometic head gasket is leaking on my boosted teg, i ran thicker gasket to lower compression to be safer on boost. I cant remember exactly how thick it is.. i was wondering if you guys knew of good reliable ones i could get? or if i should just run the stock oem.
cometic makes good gasket imo but did you put in new head studs or keep the oem bolts? maybe the head lifted a little if its boosted on stock head bolts. i have a cometic head gasket .030 in thickness i think and arp head studs on my gsr running 14psi and i haven't had any problems with it 10,000 miles so far
give more info. is it leaking coolant or oil? is it leaking inside or outside of the block? has it been leaking ever since you changed it or just started recently? does it push coolant under boost?
the most common problems have already been mentioned...
1. head/block arent straight so the gasket isnt sealing properly
2. head lift causing it to leak under boost.
3. improper install
also i think most people will reccommend an oem gasket. what engine do you have? you can boost higher compression safely with a proper tune
3. improper install
Hey dpetro1 my d16y8 leaks coolant on the front left corner of the engine..what do you think it could be?? Im in the process of installing my turbo rite now and i already have a new oem head gasket with arp head studs so do you think milling the head has to be done or can i just clean it well and spray copper on the HG to help it seal???.... Not to be a thread jacker but whats the best way to remove the power steering so i can change the HG?
1. cometic makes high quality gaskets
2. if you don't check the deck AND head for trueness and machine if needed anything MLS leaks
3. if you don't use a fine RA wheel or diamond cutter to cut the deck or head it will leak
4. if you don't torque properly or have grime anywhere around it will leak
5. you can use a red jelly assembly lube that helps prevent thread seepage and small oil leaks out of the gasket. it's anaerobic? sealer if i remember right.
3. improper install
3. improper install
