Cometic Head Gasket Woes!!!
Old Aug 4, 2002 | 06:16 PM
b00stedbyFastrax's Avatar
Default Cometic Head Gasket Woes!!!
i an using a 85mm HP Cometic HG with ARP head studs running 19 psi with race gas. i have notice that there is a oil leak from the head (Pwr Str side) and slight coolant seeping out on the left front side of the head.I am not running any aggressive timing , it is very conservative. has anyone have similar problems. or is it that the cometic HG cannot handle this high boost??
Old Aug 4, 2002 | 06:24 PM
speedworks's Avatar
Default Re: Cometic Head Gasket Woes!!! (BoostedbyFastrax)
is this a copper gasket. it is common for slight leaks with a copper head gasket. i sprayed my copper gasket with two coats of copper seal and then put a thin coat of honda bond around the water jacket holes before installing
Old Aug 4, 2002 | 06:40 PM
Default Re: Cometic Head Gasket Woes!!! (speedworks)
no. but i sprayed the HG with copper spray and also put hondabond around the oil holes.
Old Aug 4, 2002 | 06:48 PM
speedworks's Avatar
as long as the leaks are very slight i would not worry. copper gaskets are very hard to seal. if you do have to remove the head clean the gasket and surfaces
and reapply 2 coats of copper seal to both sides of the gasket. then apply a very thin coat of hondabond around the water jacket holes on the block side and the head side and reinstall.
Old Aug 4, 2002 | 06:56 PM
thanks for your input, man. i am planning on tuning at 24 psi, hope it holds.
Old Aug 4, 2002 | 07:00 PM
speedworks's Avatar
is your head or block o-ringed
Old Aug 5, 2002 | 03:38 AM
no.
Old Aug 5, 2002 | 08:32 AM
earl's Avatar
Check your valve cover gasket for the oil leak and use some Barr's stop leak.
sleepyIntegra
May 24, 2004 11:14 AM
kevinoneill
Sep 17, 2003 05:13 AM
ScottEK
Aug 13, 2003 12:42 PM
rathead
Jul 29, 2003 04:39 PM
