Quick wire question help!
Old Nov 28, 2009 | 01:01 PM
Jdm John's Avatar
Default Quick wire question help!
Ok i just put my engine in my car but its not turning over. I hear like the starter is getting electricity but no turn over. There is this wire that I dont know where it goes. If anyone could help me out and tell me where it goes that would be helpful. TIA
Old Nov 28, 2009 | 02:01 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: Quick wire question help!
looks like the starter cable
Old Nov 28, 2009 | 03:24 PM
Jdm John's Avatar
actually i found out it went to the fuse box. When I turn the ignition it makes a whinning sound and the lights dim so I'm pretty sure I need to replace my starter? Yes or no
Old Nov 28, 2009 | 04:02 PM
Kaotik_Jeffy's Avatar
New User
do you have a good charge on the batt? if so i would say yes take it out and have it tested
Old Nov 28, 2009 | 04:33 PM
Jdm John's Avatar
yeah the battery was fully charged. I'm almost positive its the starter cause of the noise its making. Plus its not even turning over.
Old Nov 28, 2009 | 04:43 PM
New User
i would say 98% its bad the other 2% cuz im not there to see or hear it makin the noise gotta have that margin for error lol
Old Nov 28, 2009 | 04:49 PM
mooze's Avatar
do you have the other end connected to the started. could b just solenoid whining. not motor
Old Nov 28, 2009 | 05:12 PM
Jdm John's Avatar
what do you mean by other end connected to the starter?
Old Nov 28, 2009 | 05:25 PM
mooze's Avatar
there is a wire that connects to the fuse box and runs down to the starter
Old Nov 28, 2009 | 06:08 PM
Anon51's Avatar
x2 the wire you're holding looks like it goes into the fuse box.
should be 2 of them. one from the alternator and another from the starter which connects to the batt positive
Old Nov 28, 2009 | 06:21 PM
Jdm John's Avatar
yeah I hooked the shown above to the fuse box. I connected it right next to another wire located in the fuse box. My car should start now I would think. I just swapped in the engine.
Old Nov 28, 2009 | 06:31 PM
mooze's Avatar
ok check the started and make sure u have 2 wires connected to it. one small one and one larger one
Old Nov 28, 2009 | 06:42 PM
Jdm John's Avatar
Hooked up + battery cable to starter on big bolt. Inserted the other black cable.
Old Nov 28, 2009 | 07:08 PM
mooze's Avatar
try giving the starter a few taps with something hard (screwdriver) and then try to fire it up
Old Nov 28, 2009 | 07:21 PM
Jdm John's Avatar
alright ill try that. Also if my battery cable isn't fully clamped on could that cause it? Again it whines.
Old Nov 28, 2009 | 07:29 PM
mooze's Avatar
that could cause a weak connection. even though battery is fully charged if it has a weak connection it could not be putting out enough for it to turn over
Old Nov 28, 2009 | 07:51 PM
itsnotfast's Avatar
Very possible. Also, make sure you thoroughly check all ground straps. That could also cause a no start.
Old Nov 28, 2009 | 08:25 PM
Anon51's Avatar
wouldn't hurt to put a battery jumper on there or a battery charger. high amp for starting.
Old Nov 28, 2009 | 10:35 PM
Jdm John's Avatar
Yeah I tried that and still nothing. What are the symptoms of a bad starter? I checked all of the grounds, all of the wires are properly put on so I might just replace the starter and go from there.
Old Nov 28, 2009 | 11:34 PM
mooze's Avatar
you usually wouldnt hear anything from the starter. nor solenoid click or anything. try taking the starter off and holding it or have someone else turn it to c if it well freespin. if it wont then its dead or not connected properly
Old Nov 29, 2009 | 10:07 AM
96_cvc_b16's Avatar
i'd say to double check that you have both of these wires on the starter.
2x0
Apr 29, 2018 09:35 AM
mikeSMASHES
Jul 8, 2010 09:13 AM
Einhander276
Jun 23, 2010 05:37 AM
homesauce
Jun 18, 2006 08:54 AM
TeginRAGE
Feb 22, 2002 11:59 AM
