H22a Distributer/Rotor Problem!!
Old Nov 28, 2009 | 11:13 AM
notEurophreesh.'s Avatar
Default H22a Distributer/Rotor Problem!!
So i was getting around to change my Distributer cap on my h22 since it was cracked and i was going to change the rotor also but as i tried to take off the rotor it completely just broke; so the little metal piece got stuck to the distributer.
what can i do?
do i have to get a new distributer?
i also have a single cam distributer on the side can i use that for now or?
thankssssssss
Old Nov 28, 2009 | 01:38 PM
delsolproblems's Avatar
Default Re: H22a Distributer/Rotor Problem!!
Rent a puller from a parts store to get it off. You may need to drill a hole through the tip of what's left of the rotor for the puller to push on the shaft.
Old Nov 28, 2009 | 01:40 PM
-and clean the corrosion off of the distributor shaft with some fine sandpaper and a clean towel before replacing the rotor.
LukieLuc
Aug 27, 2007 09:20 PM
Extreez
Jan 3, 2007 04:33 PM
93H22ACX
May 24, 2004 02:32 AM
SearchBeforeUPost!
Sep 21, 2003 06:40 AM
CTL
Jul 12, 2002 06:28 PM
