Problem with my DA tranny
Old Nov 23, 2009 | 08:04 PM
michjdm's Avatar
Default Problem with my DA tranny
hey guys, im aware that i have a bad bearing in my tranny cause it makes a lot of noise, and its really annoying...i just want to know if this will harm my tranny in the long run, or is it harmless??
Old Nov 23, 2009 | 08:39 PM
michjdm's Avatar
Default Re: Problem with my DA tranny
its the bearing inside the tranny...it makes a nasty noise when i drive the car..
Old Nov 24, 2009 | 08:28 AM
michjdm's Avatar
anyone?
Old Nov 24, 2009 | 08:35 AM
Charlie Moua's Avatar
which bearing are you talking about.....
simple answer is yes, if your tranny is making noise it will only get worse until it gives out.
Old Nov 24, 2009 | 08:45 AM
michjdm's Avatar
i dont really recall the name...its in the inside of the tranny...not the throw out bearing..
Old Nov 24, 2009 | 10:39 AM
mouab18c1's Avatar
your Input shaft bearing?
Old Nov 24, 2009 | 12:47 PM
theunknowntech's Avatar
New User
As the metal particles from the self-destructing bearing circulate thru the oil, there will be some capacity for the magnet to pick them out and isolate them, but while the magnet is still "sorting things out" there is the potential for all kinds of damage to other bearings, machined surfaces and seals. The longer you wait to get this repaired, the more damage there will be, and the higher the ultimate cost to you.
The magnet was only ever intended to pick up residual metal particles from normal wear, not to compensate for a "catastrophic failure".
My best advice to you would be to get the failed bearing replaced at the first available opportunity, or resign yourself to replacing the transmission entirely not that long afterwards. It may already be too late. Consult a good trans shop.
Old Nov 24, 2009 | 12:54 PM
twentyhurtz's Avatar
good thing about da cable transmissions- they are very cheap to replace as opposed to a hydro
Old Nov 24, 2009 | 02:01 PM
New User
You know what would be even cheaper than getting a bare-bones trans rebuild? Walking to work. No conflict of interest here. ;^b
Heck, trying to just inject some perspective.
Old Nov 24, 2009 | 02:16 PM
DumaDA's Avatar
replace it asap, worst case, try to pick up a cable b16 tranny
Old Nov 24, 2009 | 02:33 PM
michjdm's Avatar
dang...it think its too late guys hahah...its cause i just drove it with the noise for a while, and since yesterday my tranny got a lil harder, and third and fourth are hard to switch into now...agghhh! and it was perfect before...well the good thing is that ls cable trannys are cheap, but the work is a pain hah..thanks guys for the feedback
DB1_559
Jan 28, 2006 05:58 AM
ericlee303
Oct 6, 2005 07:55 AM
Y2ksi
Mar 17, 2005 03:41 PM
XRacerX
Mar 10, 2004 09:14 PM
Leb_CRX
Sep 26, 2003 12:38 AM
