whinding tranny noise
Old Sep 23, 2003 | 12:16 AM
Leb_CRX's Avatar
Default whinding tranny noise
I did a search and found nothing useful
here's the problem, I just did a tranny swap on my 97 hatch, I swapped to a 92Si tranny, I re-used my throw out bearing since it seemed fine, also cleaned all the parts with brake cleaner and use the proper grease, but now in 1st, and 2nd, and a bit in 3rd, as I accelerate, I get a whining noise, and it increases as the RPM's climb...now I am going to rule out the release bearing since it was fine on my tranny, I am just wondering what else could cause this?? also de-whines as I deccelarate...
just a background history, the tranny has been sitting in my shed for about two years, if that makes a differance, was sealed in a garbage bag, no water or anything got hear it
Thanks.
had to edit, too late, meant brake cleaner
Old Sep 23, 2003 | 12:19 AM
Average Al's Avatar
pilot bearing
as you go up in gear there is less stress on it hence less noise.
that would be my first guess then it go on to the main shaft bearing and main out put shaft bearing. Pilot bearing is on the fly wheel and is pressed out
Mochanic's Avatar
Default Re: whinding tranny noise (Leb_CRX)
de-whines?
brake fluid or brake cleaner?
Are you sure the noise started when you installed the tranny? What oil did you put in it? (did you put oil in it?)
Its not the pilot bearing, it would do it all the time... besides, I've never seen a pilot bearing make any type of noise at all!
Does the noise sound the same in 1st and 2nd, or does it sound like its faster or higher pitched the higher the gear your in?
Does the noise go away when turning either direction?
Please answer all these questions!
Old Sep 23, 2003 | 12:25 AM
Leb_CRX's Avatar
Default Re: whinding tranny noise (Mochanic)
Thanks for your post,
brake cleaner, my mistake it's 4:30 am, very tired..heh
yep the noise started when I installed the tranny, positive, I drove my car there and it was extremely quiet
I put 1.8L (approx) of Manual honda tranny fluid
the noise sounds the same but ya it goes faster as I accelerate, I am going to have to go and make a .wav file with my minidisc and post it....give me 20 minutes i'll be back...
nope the noise does not go away when I turn...still there...i'll double check but I am pretty sure it stays..
I am going to go make this into a .wav file...brb
Old Sep 23, 2003 | 12:36 AM
Mochanic's Avatar
Without accelerating, just normal driving is it there?
Same question one more time a little clearer... while going the same speed in 1st gear as in 2nd gear or even 3rd gear, does the noise seem to be any different at all? What I'm trying to figure out is does it have to do with the shaft speeds inside the tranny, or is it in the final drive gears? If at all even in the tranny...
I'm going to bed now, but I will get back with you tomorrow.
Randy
Old Sep 23, 2003 | 01:04 AM
Leb_CRX's Avatar
yep normal driving, accelerating and deceleration...
I am not sure if this is a coincidance or anything but when I went outside to make the sound files, the noise was non-excistent initially, and as the car got hotter it seem to become more appartant...weird. as for it coming from there, I can't see where else it would come from, I mean I drove the car there, and drive it daily and it's quiet (when I am not punching it...heh)...and we didnt do anything major engine related besides that today....
the sound is not differant dependent on the gear, just on RPM seems like...check out the sound #2 in this zipfile towards the end, seems to be the best one out
here's the link ...
the zip file (which has all 3): http://members.rogers.com/adaccache/sounds.zip
the first one (in case you dont have zip program): http://members.rogers.com/adaccache/sound1.wav
the second one: http://members.rogers.com/adaccache/sound2.wav
the 3rd one: http://members.rogers.com/adaccache/sound3.wav
thanks for everyone's help
Old Sep 23, 2003 | 08:08 AM
1bad-eg's Avatar
Your probably looking at diff bearings or mainshaft bearing. You really won't know until you drop the tranny and look over everything.
Old Sep 23, 2003 | 08:39 AM
pro1342's Avatar
One of the two bearings in the clutch housing is bad, sounds like input shaft bearing.
Old Sep 23, 2003 | 09:22 AM
jerseybrandon's Avatar
Sounds like mainshaft, have to open the case to know for sure.
Old Sep 23, 2003 | 11:57 PM
Leb_CRX's Avatar
Default Re: (jerseybrandon)
Thanks for everyone's reply...is this something I should be worrying about or can I let it be for some time (say 6-7 months)...I am basically waiting for my clutch to go, hoping I can do it all at once instead of having to rip off that tranny two times, it was a pain to do last night...
Thanks again!
Old Sep 24, 2003 | 12:23 PM
PupaScoopa's Avatar
Default Re: (Leb_CRX)
It could be a bad input shaft bearing or release bearing. When you're accelerating and hold the clutch slightly (so it slips, yet puts tension on the bearing) does the noise change? Does it whine in neutral at idle, then whines at a higher pitch as you rev?
Old Sep 24, 2003 | 12:48 PM
WundedSaint's Avatar
Something's wrong with your differential probably..chipped tooth, busted tooth.
Old Sep 24, 2003 | 12:51 PM
pro1342's Avatar
Default Re: (PupaScoopa)
The best way to see if it is the input shaft bearing is by pushing the clutch in and see if the noise goes away.
Old Sep 24, 2003 | 03:25 PM
AlphaKennyWun's Avatar
Default Re: whinding tranny noise (pro1342)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pro1342 &raquo;</TD></TR><TR><TD CLASS="quote">One of the two bearings in the clutch housing is bad, sounds like input shaft bearing.</TD></TR></TABLE>
yep thats what happened to mine and I had the same symptoms. It was only audible in 1st and 2nd gear and when I pushed in the clutch it went away.
A tranny rebuild shop said "input shaft bearing" but i just swapped in a new tranny instead of fixing it
Old Sep 25, 2003 | 12:47 AM
Leb_CRX's Avatar
Default Re: (pro1342)
yep it does go away if I put the clutch in
but how long will the tranny 'last' with this being in need of changed? I just want to know if I can wait out until the tranny starts slipping
Old Sep 25, 2003 | 01:15 AM
95hatch's Avatar
I think what it is, is your throwout bearing. Its a sealed bearing and your not supposed to use and type of brake cleaner or degreaser on it as that will break down any grease inside of the bearing.
Old Sep 25, 2003 | 02:51 AM
elise's Avatar
Default Re: (95hatch)
just a question quick...
does it only make that noice when your giviing it a certain amount of throttle? (like, once the noise starts, can u keep it going? and when you give it more or less gas it stops?) or can you hear it no matter how much gas your giving it through out the gear?
that noise sounds familiar..
(sorry if the question doesnt make sence..)
Old Sep 26, 2003 | 12:38 AM
Leb_CRX's Avatar
Default Re: (elise)
your question does make sence...
it seems like it begins in 1st and 2nd at around 2500, not below that
and yes the sound does come and go depending on the throttle input it seems, or maybe my AEM is just really loud
Leb_CRX's Avatar
we used the cleaner, then dryed it off, and then put the grease on it, we just wanted a clean surface since it had been sitting for a while
michjdm
Nov 24, 2009 02:33 PM
fcjohnny
20
Aug 27, 2009 09:48 AM
confusion
Nov 6, 2007 05:06 PM
ericlee303
Oct 6, 2005 07:55 AM
NipponRacing
13
Sep 5, 2003 06:42 AM
