help 1st gen B16 in my hatch I broke a valve cover stud and need to find out torque specs
I need to find out what to torque these bolts to. Anyone please help. I have heard 12ftlbs can anyone verify this
Go here and download this VTEC supplement manual. It covers the B16.
Later.
http://www.hondacrx.co.uk/
Later.
i downloaded the document and I can't find anywhere that talks about the cam shaft removal and replacement no torque specs
Cap nut for the valve cover is 7lb-ft
Camshaft holder plate is 20lb-ft
The outer one(smaller) is 7lb-ft.
This came from my Helm's.
I'm assuming that the cap nut for the valve cover is 7lb-ft is when I'm putting on the valve cover?
8mm camshaft holder plates 20 ft pounds. dohc
6 mm camshaft holder plates 84 inch pounds dohc
valve cover nuts bolts 89 inch pounds
hope this helps, I brake them all the time.
AndThenYouSay
Jan 18, 2010 05:19 PM
